Oil Temp/pressure Gauge not working???
Old Jun 11, 2009 | 04:40 PM
BADASSTT's Avatar
Question Oil Temp/pressure Gauge not working???
I just bought a 86 Z31 Turbo. The oil temp/pressure gauge is not working. I know I have oil pressure because I changed my oil today. And afterwards the oil light turned on for a second then shut off. Anyway the engine purrs like a kitten. The car has 46K miles but was rearly driven. Could something be disconnected in the engine bay, a blown fuse,or is it the oil pressure sending unit? Does it control the oil temp as well? What do you fellas think? All the other gauges are working.
Thanks
Raul
Old Jun 11, 2009 | 05:46 PM
SloppyGoat's Avatar
Most likely, the sending unit is just bad. Check the connection. If it looks good, replace it.
Old Jun 11, 2009 | 07:42 PM
BADASSTT's Avatar
Does it monitor oil temp also?
Old Jun 11, 2009 | 09:21 PM
no, oil temp sender is located in the side of the oil pan. i would recommend going with aftermarket gauges, even if you dont plan on modding your car.
Old Jun 13, 2009 | 02:46 AM
BADASSTT's Avatar
Naw I want to keep it factory. My 86 Z31T has only 46K miles on it.
Old Jun 16, 2009 | 12:07 PM
BADASSTT's Avatar
changed the oil pressure sending
Okay, I changed the oil pressure sending unit today. Mind you the Temp outside was 93. the oil pressure started to read while at idle 30 and while running 30 to 32psi. (Maybe 35psi)is this normal. I went WOT and 32-35psi. Also the oil temp gauge was running normal. Is this a normal number for these cars? I guess I dont need an oil temp sending unit after all.
Old Jun 21, 2009 | 10:23 AM
SloppyGoat's Avatar
Mine runs higher when cold (up to 60), then settles around 30 or so when it's warm. Apparently, my oil pump still works great.
davidjoe007
Mar 7, 2023 09:28 AM
topkat
Aug 15, 2009 10:17 AM
pmr2000
Mar 14, 2006 09:49 AM
jfairladyz
May 6, 2005 01:49 PM
Heat Rave R
Apr 15, 2005 04:58 PM
