Odd starting issue
Old Oct 10, 2013 | 01:38 PM
Unorthodox's Avatar
Odd starting issue
First a little background as i see no introsection, Im Brock, I own two 80s nissan s12s (200sx). And can hold my own when fixing a car, but i just ran into a problem on my buddies newly acquired z31 n/a. Hes not very forum savvy or motor smart for that matter lol. so...
Got it. Fuel pump would not turn on so it wouldn't start. I replaced the fuel pump and it then worked. Still wouldnt start. Fuel would go all the way to the FPR and stop. Aswell the FPR made a nasty sort of noise when it was active.
So he buys the part and puts it on himself, instead of waiting for me, and when i get there. Now the FPR is not making the crappy noise nice and new. But now there is no fuel pressure again because the pump wont even turn on.
He says all he touched was the FPR. And i went over everything i can think of. All wires are in tact and in the same place they were while it worked. The fuse is good. Still no fuel. Any leads would be too welcome!
Old Oct 10, 2013 | 02:04 PM
Welcome to ZDriver!
So have you checked for power at the fuel pump? If no power, have you checked the relay? From where was the fuel pump purchased?
Old Oct 11, 2013 | 05:47 AM
Unorthodox's Avatar
Yes the pump has been checked for power. The ignition was destroyed when someone tried to steal the car with a power too of some kind so there is a push button start, along with a toggle switch for the Battery and pump.
Relay. Have 3 of them and swapped them all in and none of them would change anything.
And the pump was originally out of my 84 s12 it was gently used and did have low miles. I believe i got it off summit, before i decided to buy a better model. So i took it out and put it in the z31.
Old Oct 11, 2013 | 08:47 AM
vorgo18's Avatar
the push to start was not wired up by myself or brock so I do not know any of the wires the were cut in the ignition or if there are any wires for the fuel pump in the steering column
Old Oct 11, 2013 | 11:15 AM
vorgo18's Avatar
if any one can list a diagram of the key switch so I know what wires are what I might be able to fig. this thing out but I cant find any list of wire for that part the car
1979 280z
Jan 5, 2015 02:58 PM
GreenMachine
Jul 29, 2012 08:09 AM
Lesnocker
Feb 11, 2011 01:13 PM
OpenRange
Aug 26, 2009 12:54 PM
280z racer
Sep 25, 2007 11:29 AM
