ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   Need some help (https://www.zdriver.com/forums/300zx-z31-forums-8/need-some-help-3664/)
Peters1983 Oct 4, 2002 07:53 AM
Need some help
I'm new, I just bought a 86 300ZX. The car ran when I bought it but now it won't start at all. Ther is a problem with the fuel pump not kicking on, I have checked it and it works and it is getting power all the way back to it. I was wondering if anyone can help me out here. I would really appreciate it, thanks.
Spot Oct 5, 2002 05:12 AM
Re: Need some help
Does the fuel pump kick on when the key is turned to just before the 'start' positon? There is a relay for it. If you open the passenger door, and look at the doorjamb (on the body, not on the door) you will see a black kinda triangle shaped vent. The relay is inside there. It's screwed to the body of the car, so you will probably have to access it by prying off the plastic trim panel that is part of the wheelwell cover. Check that relay, and also check the ignition relay. Also check your fuse for the fuel pump, it's the 2nd one down in the second row of fuses. If it's the fuse, then replace the fuse and try and figure out what may have blown it in the first place.
Peters1983 Oct 7, 2002 11:30 AM
Re: Need some help
I have checked all of the fuses, and already replaced the relay. I just took the ECU out the other day and there is something fried in it. I'm not sure wht it is but I know that it is not good so I am going to replace the ECU and hope that was all that was wrong with it. Would you happen to know about any recalls or anything wrong with that year? thanks for the help.
