need help with engine
Old May 18, 2008 | 04:52 PM
86300zx's Avatar
recently i have been working on my car and trying to get it running again, it has been sitting in for a while.i did a tune-up and replace the fuel pump.also checked the fuel filter. whenever i try to turn my car on it would just stay on for about a minute and then turns off. does anyone know what it might be?
Old May 18, 2008 | 06:26 PM
johnZboy's Avatar
Distinquished Guest
Wink Discombobulated Fluxometer...
The Question...
The Answer...
It should be obvious to one who has the skills, and automotive know how to accomplish a "fuel pump" replacement on a z31 that the ECU will (when asked) give you the codes needed to diagnose most of the "my car won't stay running" problems.
Other than pointing you towards diagnostic codes, I doubt anyone on the internet can assist you because that is where even an expert would have to begin.
Old May 18, 2008 | 08:57 PM
reddzx's Avatar
It could be many things. You will have to run the codes on the ECU. Not hard, just read the manual and check the possibilities one at a time. Then come back and tell what you found.
This link will get you to a free download for a Factory Service Manual.
http://www.xenonz31.com/reference.html
Old May 22, 2008 | 10:18 AM
jeezy's Avatar
i had the same prob. you need to check the tps first
300zgearhead
May 6, 2010 11:45 AM
smokingzcar
Dec 5, 2002 07:57 AM
