need help
Old May 20, 2008 | 09:19 AM
  #151
Mhinrichs's Avatar
Mr. Fancy Connectors
seriously have you compression tested this damned car? before you rip the head off go spend 12 bucks on a thread in compression gauge and make sure thats the problem.
Old May 20, 2008 | 02:49 PM
  #152
watz compreshun?
Old May 20, 2008 | 02:59 PM
  #153
watz compreshun?
its teh noize your ingene maykes when yew try two start it
Old May 20, 2008 | 07:39 PM
  #154
tonsoffun300zx's Avatar
West Coast!
ok i found out that my compression is good but my turbo is going out. probably why hoov had a spring hooked to the waste gate. so now i gi from the frying pan into the fire fun but worth it
Old May 20, 2008 | 08:22 PM
  #155
How do you know your turbo is going out?
Old May 20, 2008 | 08:24 PM
  #156
West Coast!
cause it's not spooling till about 3800rpm and if not a head gasket what would cause such low boost?
Old May 20, 2008 | 09:10 PM
  #157
**** waste gate, vacuum leaks cause they also equal boost leaks. or an improperly set boost controller. how to tell if your turbo is bad, take off the intake piping on it so you can see the compressor wheel, try to spin it and see if the shaft wobbles, if it rocks around or has resistance spinning it its probably bad, also look at the condition of the compressor blades.
Old May 21, 2008 | 06:34 PM
  #158
West Coast!
ok so i basically have to take off my turbo cause my "big meaty claws" barely fit but a mechanic friend of mine actually touched it and said it spun properly but my hoses looked oil soaked and they were probably ripped.
Old May 21, 2008 | 06:37 PM
  #159
KasbeKZ's Avatar
Pr0n Addict
you don't need to take it off because your hands won't fit in.... wouldn't you first think to use a tool rather then go through so much extra work just to check?
Old May 21, 2008 | 06:40 PM
  #160
West Coast!
what kind of tool? like make my little brother check? or like a set of needle nose pliers. but replacing everything can't hurt so im just going to replace all the vacuum lines on the turbo and all the other ones. and also does anybody have a tps connector not the sensor itself but the wire that connects to it cause mine is green and looks like it never makes contact.
Old May 21, 2008 | 06:42 PM
  #161
KasbeKZ's Avatar
Pr0n Addict
it will NEVER run again
Old May 21, 2008 | 06:43 PM
  #162
West Coast!
why cause im replacing the vacuum hoses?
Old May 21, 2008 | 09:02 PM
  #163
West Coast!
ecu codes
ok i just did my ecu diagnostic and i got: crank angle sensor,fuel pump circut, exhaust gas sensor, and no malfunction wtf is going on first it has problems then it's ok im not sure what to make of it any help?i did my homework this time
Old May 21, 2008 | 09:05 PM
  #164
West Coast!
also i have two things that connect to my ecu kinda like a spare or i don't know i'll take pics tomorrow.
