need help
up there as in to the second bar of the oil temp gauge(not sure what is relates to but it's more than 160. and yes the clutch fan is for cooling the radiator
ohh i was worried about the temp again. and im not sure but the whole car was lagging and i got this really loud noise after i would rev the car. i also felt it as i was driving
is that an aftermarket oil temp gauge?
Originally Posted by Mhinrichs
its probably the freaking oil pressure gauge hes talking about. Hes not the brightest you know.
Hey nismo you ever get that head installed?
I hope to have it back middle of next week.
define heavy... Mines got 272 cam courtesy of the PO. I am gonna pull off the POV this weekend and modify it to take 13psi boost. Then I am gonna install my new MBC if it gets here in time. Gotta get ready for AutoX this sunday.
no no timing i have to get it to idle right but i have a few vacuum leaks.
isn't that the only thing that was wrong with the 240 back in the day?
"vacuum leaks"
Is this going to be a circle?
Make sure to mount your vid cam for AutoX! And take lots of pics.
Some porting, 5 angle valve grind, decking the head .020, new springs, and I'm still debating titanium spring hardware. I'm keeping the stock turbo cam... everything I've read says to keep the stocker unless the goal is over 400hp.
I will get lots of pics, but I dont know how much I am running mine, it still needs bushings and what nots. I got energy suspension in mind, just gotta get the money up, and am still debating on buying the black widow pearl, bowling ball. So bushing may wait.
i like out side vids better than inside vids. also, an upgraded cam is going to help no matter what a larger lift and longer duration = more air flow so i would do it because its a cheap mod and will just help you reach your goal that much easier. besides, you and me both know there's no such thing as enough power
