Leaking fuild from middle of car
Guest
Posts: n/a
I need the input of some of the Z masters. I have what looks to be an oil leak from underneath the middle of the car. Near the transmission (5-speed) feels like oil when I touch it and rub it between my fingers. Not sure what type of fuild it really is though and I check the oil level every week, which hasn't needed any oil but I'm staining my garage floor and hearing it from the spouse
Where could the leak be coming from ? and what do I need to do to correct it? I have put some CD 2 in the oil for any additional leaks.
Thanks in advance!
Thanks in advance!
I agree that the rear main is the most likely culprit. While you have the tranny out for replacing that, it would be a VERY good idea to replace the front and rear oil seals on the transmission too (the input and output shaft seals). It may also be a good time to replace the clutch if needed.
Turbo86
05-07-2006 01:50 PM
