just a few ?s
Guest
Posts: n/a
Let me start from the begining, last week I replaced my ball joints on my 84 300zx n/a, this is the second time I had to do this, the passenger side went as before, pressed out, pressed in then presto, done. However, the driverside was a different story, I had to press out the old one, everything is good up until this point, once press out, I went to press the new one in, but to my surprise I found that I could easiely install it without pressing it inn, just push hold and clamp. Didn't make sense, so I droped it out, measured it. But it was the same size. Now its loose and wobbles. I was thinking last night on what I could try to fix this thing, Is it possible to cut a pop can, (yes I know) then press it into place to take up the extra slack, or should I tack weld the sides? Any idea or suggestions would be great. Thanks. Oh yeah one more thing, Does anyone know the best and most logical way to adjust the air/fuel ratio on this thing. Seems like its always running rich.
Thanks.
Thanks.
