Incorrect polarity
Old Nov 14, 2016 | 08:46 PM
Rej Chartrand's Avatar
Incorrect polarity
Long story short:
Boosted my car. Friend reversed polarity on booster cables.
Care won't start. There was smoke coming from the ecu which I've confirmed is burnt. I also burnt a fuseable link.
Is there anything else that might have been destroyed that I should look at.
Might be worth adding that the engine doesn't even try to turn over. Just a clunk sound and a drop in voltage.
Also, the warning lights are all on, regardless if the key is in the ignition.
Old Nov 15, 2016 | 06:48 AM
Click: https://www.zdriver.com/forums/280zx...l-issue-41021/
Old Nov 15, 2016 | 05:05 PM
Donn144's Avatar
OY..So sorry my Z friend!
Old Nov 17, 2016 | 07:11 PM
86tcoupe's Avatar
the jump box didn't have the polarity sensor on the pos clamp?
think you will have to see if the starter jumps , test the starter relay , on the just clicks
after you find a ECU... that is.
I.ve worked places where the porter is a no nothing teen that does this
but then the service manager asked me where the valves in the engine were.
