I'm too Short...
Old Feb 17, 2014 | 06:27 AM
Gerbil's Avatar
I'm too Short...
So the project, my NA2T swap running an Infiniti M30 ECU has been on the road for a month now. It's a thrill to drive...
Because I am so short, I have to sit really close to the wheel so I can push the clutch to the floor, even though I have no problem reaching the gas and brake.
Is there anything I can do to fix this? I love the car.
Old Feb 17, 2014 | 07:02 AM
Well the clutch pedal must travel farther (to the floor) to fully engage / disengage than the brake. You might be able to tweak the slave cylinder to fully engage before the pedal bottoms out, then you could just fab up a stop for the pedal. Other than that I suggest attaching a block of wood to the clutch pedal or thicker pedal covers.
Old Feb 17, 2014 | 08:09 AM
Delecroix's Avatar
+1 to the pedal covers. Wearing thicker boots works as well.
Old Feb 17, 2014 | 05:47 PM
zxguy1986's Avatar
In this case, a higher (built-up) clutch pedal should work OK since the right foot works only accel and brake. No cross-glide required from them to a higher clutch pedal on the left. Still it would take some practice to get used to. We like to do the footwork without thinking about it.
When you figure out how much you need to bring the clutch pedal up, (1"? 1-1/2"?) make your wood block, take the pedal cover off and screw it with large-head wood screws to the bottom of the block. Then snap the pedal cover back on the pedal. Make sure it's stable and secure with some test drives.
If you let anyone else drive, tell them about the pedal height first.
Old Feb 18, 2014 | 09:56 AM
Gerbil's Avatar
Thanks, the wood block is ok for now. I'll keep my eyes open for something with a more "finished" look.
I'll post pics of the car at some point, it looks pretty cool.
hogboy36
24
Nov 4, 2005 08:04 AM
BlinginZ
Jun 30, 2005 10:43 PM
apollo
May 21, 2005 08:13 PM
nka04a
Mar 15, 2005 07:02 AM
lilx240z
May 6, 2001 06:43 AM
