I need help with TPS
Re: I need help with TPS
Unplug elec connector (both if auto), loosen the 2 screws holding the TPS on the TB, rotate it counter clockwise, using an ohmmeter w/ the probes on the top 2 pins, rotate the TPS back 'til the meter shows continuity. Hold it steady while you tighten the screws. Check it again to make sure you didn't move it when you tightened the screws. Plug it up and go.
ZenArcher
ZenArcher
