ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   Heater / Air Conditioner controls (https://www.zdriver.com/forums/300zx-z31-forums-8/heater-air-conditioner-controls-352/)
Dolomite May 17, 2001 01:01 PM
I have a 1985 300ZX, and he cotrols for the heater / air conditioner seems to be stuck on defrost. No matter what button you select on the controls you only get air from the defrost vent. Has anyone had a similar experience? Is it the control module that needs to be replaced?
Skaitan May 17, 2001 04:56 PM
Re: Heater / Air Conditioner controls
Check your vacuum hoses, if you have a vacuum leak that will cause your heater controls to malfunction. I've had that happen waaaayyy too many times. Dod you also have problems with your air temp being always warm unless you turn it all the way to cold? If so, it's your vacuum lines for sure =)
zsky May 25, 2001 05:26 PM
The same sort of thing happened to my 85 300zx and I found it was a small hose that had come off the vaccum pump motor which is behind the right headlight I put it back on and all the heater controls worked like new again.
Ghostz May 26, 2001 11:11 PM
I also had the same problem and the vacuum lines were the ultimate culprit.
Ghost
ZenArcher May 27, 2001 06:06 AM
Check those 2 little recessed controls too,buy the previous posts probly nailed it.Good luck!
ZenArcher
