headlight problem
Old Jun 3, 2001 | 08:46 PM
Spot's Avatar
Re: headlight problem
probably the headlight switch on the column, take off the steering wheel, remove the switch (tiny phillips - 2 screws, gold colored ones), pull the thin plastic cover off the backside and clean with some fine sandpaper (like 400 grit), plug it in and test it. also try electric parts cleaner - i think u can get it at radio shack. it's a spray stuff, i'd try that first and then resort to sandpaper cleaning. you can check for proper continuity if you have a mulitmeter and see exactly which ones are bad (or not).
Nad3bot91'z32
Apr 3, 2014 12:57 PM
jeffro
Aug 10, 2012 09:26 PM
walton99
Jul 15, 2010 06:19 AM
BreakbeatBob
May 26, 2002 07:15 PM
Wolfe
Jan 30, 2002 06:34 PM
