Headlight High Beam problem
Old Dec 1, 2001 | 09:49 PM
Spot's Avatar
Re: Headlight High Beam problem
it could be the switch itself. remove the steering wheel, and the 3 tiny phillips screws holding it to the cluster of switches around the steering shaft, and you'll see the backside of the switch has a thin cover over it. gently pry that loose and either try contact cleaner, and if that doesnt work, some fine emery cloth to clean the contacts.
Nad3bot91'z32
Apr 3, 2014 12:57 PM
KevinsOffroad
Mar 12, 2014 10:14 AM
greenzee
May 24, 2011 09:30 AM
merjii
Nov 8, 2005 01:22 PM
kolts
Aug 3, 2002 01:40 AM
