Glue
The rear vinyl deck cover that mounts between the shock towers and rolls out to cover the rear deck began to separate along the edge that you pull back to cover up your belongings. I spent more effort than I want to talk about trying to find an adhesive to put it back together. So nobody else has to goop up the back of the car, save yourself a lot of aggravation and buy contact cement. You won't even need to use clamps if you do it right. It's the neatest fix I've found so far. Thought some of you might like to know!
Re: Glue
mine was doing the same. i used GOOP and clamps .
still holding http://www.speed-city.com/Zkarma/Z%2...res/Zintro.gif |
| All times are GMT -7. The time now is 09:50 PM. |
