Funny noise coming from behind dash
I just purchased a 1987 that has a funny sound coming from behind the dash maybe around the cove box. It almost sounds like a stepper mounter that lost its control. Any ideal what I should look for?
Byron |
maybe a clown?
have you looked under the dash with a flashlight yet?
theres a lot of crap behind the dash so you cant really just automatically point out one thing, you just have to get in there and try and find it. |
well back in 1985 they started putting these little fuzzy things behind the box. look towards the right side upward. theres a little door you can pop open and you should see it. i think they called it a rabbit. good luck!
Blower motor is in that area. More than likely it's a vacuum actuator in the duct works for the heat/AC system.
Originally Posted by jrealmuto1
(Post 275193)
good chance its the blower motor. if it was a vaccum problem you'd notice some chaos. Vaccuum problems SUCK! ITS BADD JOO JOO!:103:
more likely what reddzx said. easy enough to pull the dash and look at the stuff.
Does your car have the auto climate control grill on the dash ? It is about the size of a quarter and is closer to the passenger side of the dash.
There is a small silver box with a fan that has a hose that hooks to the grill coming through the dash. On my Z, that small fan was making a zinging noise(like a small fan hitting the casing). I replaced the fan with another one i had and it quit. You have to pull the glove box to see it, located just under the gauge pod. |
