Fuel Pressure Regulator
A couple of weeks ago I got a 86 300zx(t). While trying to start it and being unsuccessful, I noticed my FPR is missing the connector...completely. I have no idea where the wire would be that goes to the FPR. So question 1, from the FPR, where does the wire go to/ come from? I need to know so it can work and question 2, if I get one of those Ebay FPR, can i use it on this car or no? Thanx for helping me out
Originally Posted by MistaZ31Turbo
(Post 251261)
You need to be more specific about the ebay FPR. If it's adjustable and boost referenced, it's probably a waste of money unless you have the performance modifications to need it. |
Originally Posted by mike88se
(Post 251265)
The other end of your temp sensor wire should be connected to your ECU. I think it's basically for hot starts.
(Post 251295)
Which temp wire are you referring to? I didnt know the aftermarket FPR was adjustable. The reason im thinking of getting one is because I dont even know if the stock one is working or not.
Post a link to that ebay FPR if you want to talk about that. |
The Ebay FPR is just an idea at the moment. What I need to know where does the wire that plugs into the FPR come from. Im not quite good with fuel systems yet but I figure this car isnt going to run until I get power to the FPR.
(Post 251311)
http://www.carfiche.com/ DL a factory service manual |
| All times are GMT -7. The time now is 12:31 AM. |
