engine stalls after 30 seconds
Old Apr 12, 2014 | 04:19 PM
Wheatstraw's Avatar
I have a '84 n/a also and I have the same problem.The car runs 30 sec. and dies,it starts right back up and runs for another 30 sec. Did you find out what the problem is?
Old Apr 12, 2014 | 05:40 PM
rogerz's Avatar
Grumpy & Helpful
here are some things may not fix the problem but will prevent others down the road:
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
put a pressure gage on the fuel ring and see if pressure remains steady as it dies and then what happens. if it is pump quitting then try a hot wire direct and see if that works. after that study the schematics (download fsm from xenon). Might be a faulty relay.
Old Apr 12, 2014 | 06:50 PM
PredatorZ's Avatar
Fsm
In the Engine Fuel and Emissions Control section page EF&EC-27 begins the diagnostic info for your issue, most likely a bad relay, the 30 seconds is pre programmed starting cycle, after that it depends on the relay to continue operation. Older Z's , like 280ZX used 3 different relays to control the fuel pump, from what I can see the z31 uses just one, so it must have a bad side, or bad connection, pull it out and re seat it, just might fix your problem. If not replace the relay (as per Rogerz).
nerdbebo
May 22, 2008 11:45 AM
drisky
Oct 27, 2007 04:03 PM
venom8343
Oct 15, 2006 12:43 AM
crazywing99
May 3, 2004 02:46 AM
buffet33
Mar 22, 2002 04:11 PM
