electric clutch fan
Old Sep 9, 2008 | 12:09 PM
tonsoffun300zx's Avatar
West Coast!
electric clutch fan
ok so my clutch fan is a POS and i want to upgrade to an electric one but the problem im having is clearance would it be possible to make one fit even though the radiator is slanted and also would i need to keep the cowl thing if i go with an electric fan?
Old Sep 9, 2008 | 12:18 PM
Endless are your options... I dunno what you're talking about "clearance" wise... there's a TON more room than any S30 / S130.
www.redz31.net and www.az-zbum.com have tons of info on electric rad fans. Checky!!!
http://redz31.net/turbofaq/intercoolers.html
Old Sep 9, 2008 | 12:22 PM
West Coast!
cool thanks that would open up a few more options like a hole in the front facia to cool the engine bay more. and also im going to hook it up to my ignition so that when i start the car the fan blows constantly while the car is on.
i was also thinking about getting two for the front and one big one for the back would that be overkill?
Old Sep 9, 2008 | 01:50 PM
thats dumb.... hook it up through a temp sensor and a relay if its always on the engine will be way to slow on warm up, remember cold engine dont perform good, warm engines do with cold intake air... also the fan motor can burn out faster, and idk what winters are like there but here i didnt even need a fan on cause my turbo S30 would never fully warm up if i moved at 20 mph or faster haha. and dude, get either two small fans on the back or just one big one, 3 fans like that is really dumb and will probably create for turbulence than proper air flow
Old Sep 9, 2008 | 02:18 PM
West Coast!
two mid side ones in the back will do and now i want to intercool it.
Old Sep 9, 2008 | 05:43 PM
dude, leave the car alone, if you cant figure out how a simple turbo timer wires in, how to replace shocks, and how to adjust the clutch. then you dont need to be screwing with making a wiring harness for an un needed electric fan, i ran that car without a fan for 45 minutes without it getting above 160. i dont think you need a fan. also doing an intercooler would be WAY above your level. just leave the car alone, change the oil and drive it! or sell it too me.
Old Sep 9, 2008 | 06:27 PM
West Coast!
i have a friend who used to work for nissan im going to pay him to install everything for me but really hoov i need new shocks and struts. and you remember the fan it was all eaten and so was the shround plus it's kinda loose like a korean hooker that could suck the chrome off your hitch
Old Sep 9, 2008 | 07:02 PM
tighten the bolts down then, the shroud is and will always be loose, the fan should be fine unless something actually breaks off it, then replace it! trust me having someone to install everything as well as buying the parts to do something so simple could cost you over $1k i was thinking on using a z32 fan as a replacement, but never really got to try it.
Old Sep 9, 2008 | 07:21 PM
West Coast!
well it's all eaten away and i was thinking a fan from a turbo supra i found one almost new it still had the stickers and the fan was tight but not to tight.
Old Sep 9, 2008 | 07:24 PM
get one from an early 90's v6 maxima or sentra. and just wire it into a relay.
Old Sep 9, 2008 | 07:26 PM
West Coast!
an elecrtic? but im going to try out the supra one another 300zxt at the junk yard and what pieces should i take from the 300zxt at the yard
Old Sep 9, 2008 | 07:29 PM
nothing, you dont need anything, unless you want to replace that passenger side window motor.
Old Sep 9, 2008 | 07:30 PM
oh and the supra fan blade doesnt fit.
Old Sep 9, 2008 | 07:31 PM
West Coast!
well i'll try it out on the junkyard car and fab something up and look:http://inlandempire.craigslist.org/cto/830593316.html
Old Sep 9, 2008 | 07:36 PM
looks like a future lemon.
Old Sep 9, 2008 | 07:47 PM
West Coast!
and is the fan going to be electric? the one from the maxima
Old Sep 9, 2008 | 07:55 PM
yep maxima and sentra are FWD with the vg30e vq30de...etc and both have bitching fans.
Old Sep 9, 2008 | 08:01 PM
West Coast!
ok cool but which relay? and im going home now i'll catch you later hoov good luky and don't get shot
Old Sep 10, 2008 | 12:46 PM
get a little 30 amp relay avail. at any parts store from $5-15
Old Oct 7, 2008 | 10:46 AM
Zilvia's Avatar
u dont need a relay or thermo switch
jus grab some fans from a 84 stanza or some other small nissan and it pulls less than 15amps
Old Oct 7, 2008 | 01:17 PM
Indeed... you don't NEED relays... just a FIRE EXTINGUISHER when the wires melt.
decalservice
Aug 26, 2012 12:16 AM
JSimpson
FS: 300ZX (90-96)
Jul 25, 2011 10:59 PM
Niku-Sama
Sep 28, 2008 12:32 PM
skupy
Nov 14, 2005 01:42 PM
Las VegaZ
Aug 31, 2004 04:00 AM
