ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   Digital dash power supply components (https://www.zdriver.com/forums/300zx-z31-forums-8/digital-dash-power-supply-components-42725/)
RallyZX Oct 23, 2018 10:53 AM
So the digital dash on my 84 300zx turbo went out.I tried to resolder it a couple times with no joy, so I took it to a shop that specializes in repairing electronic modules.They said it has a blown transformer but it doesn't have a part number or specs on it so they can't replace it.I've spent the past couple hours opening up everything I could think of that would have a transformer to salvage it from with no luck. So before I admit defeat anyone happen to know a part number or the specs of the transformers in the power supply?Right now digital dash power supply units can be had from $100-300 on ebay but there is no way of knowing their condition,indeed even mine has writing on it indicating it came from a junkyard.
xnick2222x Oct 30, 2018 09:21 AM
If its a 84 the power supply number would be 24821-01P11. Can you provide a picture of the power supply?
RallyZX Nov 29, 2018 01:40 AM
The power supply has a sticker that says 24821 01P11,22370-FL7010,Lot No. 2 804,TDK Japan, and CE-0491M.
Although there is writing in marker on it that says 86 300zx Digi Dash pwr unit &298 LIST,Indicating that it has been replaced already.Although that doesnt help in tracking down transformers.
86tcoupe Nov 30, 2018 07:26 AM
A big problem was the liquid crystal disp. Going bad from sitting in 160 degree heat ,
sure it will function when power applied?
I remember customers having on going probs related to this
​​​​​​​techs were using old electrical load testers. Warping IC chips
RallyZX Nov 30, 2018 11:53 AM
At this point I don't know.The car was parked for a while because I had a strut gland nut come unscrewed while I was driving it, that boogered up the threads in the strut housing, but I was able to file the burrs and eventually get it thread back on.When I started the car the digital dash worked sometimes.When it didn't just hitting the dash near the power supply would bring it back to life.Until it didnt.
RallyZX Dec 16, 2018 04:01 PM
Is there a functional difference between the early and late digital dash power supplies? Mine is 24821 01P11, but on ebay I can only find the 24820 21P00.
Ron Maiorano Jun 11, 2019 12:24 PM
i have a 1986 digital display on my 300 zx , it works once in a while. I finally removed it and jiggled the connections and it went on. Is that the Power module thats bad or something else ? These modules are expensive. I cant afford buying on just to find out its a loose wire somewhere else. Whats the chances its the module thats really faulty?
RallyZX Jun 19, 2019 02:00 PM
I'm not having much luck finding a good condition power supply.Would it be possible to bypass the digital dash and its power supply and run the wires that went to the power supply to a couple of aftermarket gauges?Analog clusters arn't too expensive on ebay but then I would still need to track down a wiring harness for the dash as well.Not to mention pulling the dash itself which as I understand it is quite a PITA.
