Creaky doors!
Old Jun 21, 2009 | 09:59 AM
SloppyGoat's Avatar
Creaky doors!
Why do my doors creak when they're closed and I go over bumps? It's not a rattling, but definitely a creaking. Is it just because the weatherstripping is old, or the strikers, or what? (Neither look bad) It's driving me crazy, and I can't figure out what the hell is creaking. It doesn't matter if the windows are up or down. The only way it stops is if I open the door, so I assume it must be just the doors flexing a bit against the body? There is no play in the hinges, as far as I can tell. Is there a way to stop that?
Old Jun 23, 2009 | 01:31 PM
kittyz's Avatar
nah i think its just like how you cant open the door if the car is jacked up. the body just moves. you could try the weatherstripping since you said its old and prolly needs to be replaced anyways so go for it.
Old Jun 23, 2009 | 03:47 PM
SloppyGoat's Avatar
Actually, that stripping looks good. Not even cracked or anything. Yeah, I think it just flexes enough to make them scrub a bit. Probably nothing I can do about it. Weatherstripping is very expensive for these cars. I already bit the bullet and bought the $500 dollars worth of T-top stripping, and it still leaks. I need to replace the one small strip that goes across the edge of the tops. I didn't get those, because the place I got the discounted T-top stripping from did not sell those pieces.
Old Jun 23, 2009 | 04:44 PM
try spraying a bunch of WD40 on the hinges and lube up the latch.
Old Jun 24, 2009 | 04:46 AM
SloppyGoat's Avatar
It actually is coming from the rear of the doors, but I don't suppose that could hurt. I'll also try spraying the weatherstripping down with something. Maybe that will help identify where it's coming from. Any suggestions on what to put on the rubber? Petroleum products will only dry and crack it eventually, I know. Perhaps a rubber reconditioner or some sort? Not sure where to get something like that, though.
Old Jun 24, 2009 | 06:39 AM
what i have used on creaking weather stripping a very light amount of vaseline, if you dont mind a little grease, putting a LIGHT layer of axle grease or bearing grease.
Old Jun 24, 2009 | 06:43 AM
SloppyGoat's Avatar
Unfortunately, those are petroleum products, and will dry out rubber, though. You'll actually be drying it out, in the long run.
Old Jun 24, 2009 | 07:14 AM
kittyz's Avatar
yah good luck with whatever yah do.
Old Jun 24, 2009 | 07:18 AM
SloppyGoat's Avatar
Thanks! I believe I'll try PAM cooking spray. That should at least give temporary lubrication and if it stops, then I'll know I've found the problem. I think rubber reconditoner will be the best solution, if I can figure out where to get it.
Old Jun 25, 2009 | 07:53 PM
SloppyGoat's Avatar
Hey! PAM cooking spray actually worked! My doors are not creaking anymore.
Old Jun 30, 2009 | 07:23 AM
kittyz's Avatar
congrats!! i wish i had yah luck...
Old Jun 30, 2009 | 01:38 PM
SloppyGoat's Avatar
Now if I can just get the T-tops to stop leaking! I have the strips on the way. I've replaced the most expensive parts already. I hope they'll stop dripping as soon as I replace that one little piece that goes across the tops.
Old Jun 30, 2009 | 02:52 PM
kittyz's Avatar
mine do too. where do you get the strips and that little piece(thats prolly what it is).
Old Jun 30, 2009 | 03:18 PM
SloppyGoat's Avatar
It's very expensive for the biggest pieces that go around the tops and down the pillars, but the small strip is available from Nissan. It's cheaper to get it from http://nismoparts.com. I got the strips that go around the tops and windows at this place.
http://www.datsunrestore.com/datsun_stuff.html
Wow, I'm glad I got them when I did! That place seems to be down, now. They were about $565 bucks for the set. But that was definitely the cheapest I found anywhere. They had a small selection of Z31 parts and the weatherstripping just happened to be one of them. I hope they're not down for good.
They did not have the T-top strips, but they're only like $35 bucks per side if you order them online. (The small piece that runs along the mirror section, I got from nismoparts, too. They cost way too much, if you ask me!) Nismoparts is actually Bruce Titus Nissan in Tacoma, WA, but they give discounts for ordering from the nismoparts link. If/when you call them, you just have to make sure they know you're calling via the online link. I just ordered them today. Ask for Mike Stone and tell him Mike sent ya. (He's gotten to know me. I've given them a lot of money! LOL)
Old Jul 1, 2009 | 07:34 AM
kittyz's Avatar
yah thats my whole paycheck this month. i think i'll stick to my towel seat cover for now. but thanks! actually i might do the cheaper first and see if that works.
Old Jul 1, 2009 | 10:35 AM
SloppyGoat's Avatar
Yeah, it took me a very long time to pull the trigger on that, but I justified it because my interior is in such good shape, and paying someone to redo the interior and buying new carpet would cost considerably more. Plus, it's not only ruined my headliner, but I'm also getting tired of trying to hold a towel over each window when I take it through a carwash!
Z's are fun, but yes, you do have to throw endless money into them, if you don't want them to turn into junk within a few years. Maybe one day I'll catch up. I believe I can see the light at the end of the tunnel anyway.
Old Jul 18, 2009 | 03:08 PM
techdaddy's Avatar
Leaky t-top fix!
Look up this subject on Z31.com. They have a couple of sugestions. 1st is to adjust the t-top mounting points. 2nd is to use silly puddy as a sealant. it looks ugly but seems to work really good. Personally I am going to look for a slicktop and drop a VG30DET in it! Wahoo!!!!
Old Jul 18, 2009 | 04:06 PM
SloppyGoat's Avatar
I have the short weatherstripping pieces coming soon. I hope they seal it up a bit better. Silly putty, eh? Yeah, I wish it was a slicktop now. T-tops are a pain in the ***. I wish they'd have just put a sunroof in it, like the 240SX or Maxima, or something.
Old Jul 18, 2009 | 10:54 PM
SloppyGoat's Avatar
I'm not sure exactly what you searched for, but "creaky doors", "leaky doors", or "leaky t-tops" brings up a bunch of **** not even remotely related to the topic. Their search sucks *****!
Old Jul 20, 2009 | 07:06 PM
techdaddy's Avatar
Yeah, it does. Not sure about what I searched for specificaly bot I did find it eventualy. Location for the adjustors can be found in a haynes manual.
Old Jul 20, 2009 | 07:09 PM
SloppyGoat's Avatar
I didn't even know the tops could be adjusted. Maybe they need to be tweaked a bit. I'll take a look at my Haynes manual. I would think replacing all the weatherstipping and worn out window track pieces should have some affect, though.
Oh, I see. I really think it just needs the final T-top strips replaced, and maybe a light window adjustment. I can't see where adjusting those points would help anything, in my case. Interesting to know those are adjustable, though.
Lesnocker
Nov 22, 2009 12:43 PM
n_2_fairladyz
Aug 24, 2004 07:02 PM
HybridZWannabE
Nov 24, 2003 10:08 PM
nightlights
Apr 25, 2002 01:07 PM
