Consistently bad compression
Old Nov 29, 2020 | 04:22 PM
A1dan_87's Avatar
Question Consistently bad compression
Recently picked up a Z that had a head gasket rebuild done, but after purchasing the car, we found that it just never quite ran right. Upon a compression test, ALL 6 cylinders came back spot on at 90 PSI. This car is *really* rough around the edges, but I'm hoping as a project, I can breathe a little life into it- starting with the motor.
Took the timing system apart, and turns out, it was REALLY far out. Something like 4-6 teeth depending on side, I have absolutely no idea how this car didn't blow up.
It didn't come with a rear timing cover, my guess being when they re-assembled the timing belt they 'guessed', but got it slightly wrong. Going to re-assemble later this week (New cam timing gears + rear cover) and do a compression test.
Image below is with the engine at TDC, if I remember correctly.
Lost hope thinking that things will improve after re-install?
smileymatthew
Dec 30, 2015 09:37 PM
Lesnocker
Mar 24, 2013 09:07 PM
vgz32john
Aug 31, 2009 10:46 AM
Z_Unleashed
Jun 27, 2005 02:52 PM
Brandar77
Oct 9, 2003 01:42 PM
