Car Won't Stay On
ok my car has been sitting in the garage for some time now, because i don't really know how to fix the problem. when i start the car it stays on for about a second or two then the rpm starts slowly going down to 0. also while the car car is on for the few seconds i step on the gas pedal just to see if it will help stay on a bit longer, it actually helps the car turn off and feels like there is a delay when i do press down on it. another thing is i've used some starter fluid while the car is on and this helps the car stay on longer but when i stop feeding it the fluid, it slowly dies on me. i have check the lines and fuel is coming to the motor, so if anyone could help i would highly appreciate it. THanks.
how much gas do you have?
sounds like something i had , i just adjust my air to fuel and throttle adjustment screw, in the mornings i have to give it a little gas and cut my headlights on and it stays crank, after warmed up, it runs perfect. lol
It sounds like your problem might be a sensor, such as the CHTS or O2. Try running the codes and see if it picks up anything.
Old Thread...but I have the same problem...
What was the problem? Did you ever solve it?
Originally Posted by sluggo1246
(Post 318455)
86300zx Registered User Last Activity: 12-17-2010 12:15 PM |
| All times are GMT -7. The time now is 10:41 PM. |
