Battery power draining
What engine componet would drain a new battery and prevent the engine from running? I recently installled a Bosch alternator 2 months ago was told that could be causing the drain by not supplying enough amps. Should I go with nissan's alternator. I have a 1986 na.
Thx. |
Re: Battery power draining
have the alternator tested. autozone type places often test them for free. It's not uncommon to have a new one that is bad right out of the box.
It was tested and checked out ok. Why after a couple of months would this happen. Would a short possibly cause any of this?
cause some do that,I know a guy that what through 3 of them in a short time,these where auto zone one's .I bought one at Pep Boys and didn't have it tested,guess what it didn't work peggged the volt meter.Had to change it out again.
I just had the battery fully charged and auto zone tested alternator and was putting out negative amps. When I took this alternator to BAP auto parts 2 months ago,it tested fine.
Could there possibly be something between the alternator and battery causing this problem? I have no problem with changing it out, just want to be sure I guess. |
| All times are GMT -7. The time now is 08:24 PM. |
