Air vents only work in cold weather
Old 10-18-2017, 11:27 AM
The85NA's Avatar
Angry Air vents only work in cold weather
Ok i own an 85 Na model with the auto climate. The system is being very odd and air only comes out the regular vents when it is colder outside(65°f or below). It seems if the temp outside is hotter than that hot air will proceed to blast thru the defrost vents which seems common in these cars. Any advice why this weird situation would be happening would help a ton! Thanks!
The85NA is offline
Old 10-20-2017, 06:22 AM
86tcoupe's Avatar
why build a simple easy fixable proven system when you can build a complex , bit experimental , high # part cluster f=÷k ... lol
check the vacuum lines ,
vac switcheroo valve ,stuck actuator , power to them a stuck door itself , no heat if the temp is below ,55? The hc coolant needs to come up for the blower to operate, the blend door has a stout return spring so it takes everything , in top shape ,etc...etc
86tcoupe is offline
luvatenor
05-30-2014 11:23 AM
swlabr
02-07-2014 06:59 PM
gbpxl
02-19-2013 06:06 AM
Pipsqueak
01-12-2013 08:02 PM
brownjack
08-18-2002 11:23 PM
Quick Reply: Air vents only work in cold weather
