Accessing throttle chamber
Old Jun 10, 2002 | 09:49 PM
Spot's Avatar
Re: Accessing throttle chamber
just loosen the clamps and keep yanking. it gets hard and non-pliable after years of heat. try prying with a screwdriver against the tb. I had to cut one off and replaced it with a new one (brand vulco, i can find out diameter for you tomorrow or you can bring your old one to a parts place to get correct size)
just to be clear - i am referring to the black hose that connects intake pipe to throttle body.
the intake pipe is held on with 2 screws on non-turbo's, and held on with clamp at the turbo and a 10mm bolt to a bracket on turbo cars.
Old Jun 11, 2002 | 03:03 AM
Spot's Avatar
here's a pic of the location of hte things holding it on. it's usually REALLY hard to get off, but check the pic anyway to make sure you got the bolts that hold it off.
Old Jun 12, 2002 | 05:28 AM
Spot's Avatar
I clipped it from the microfiche.
scoobydoo512
Nov 14, 2010 09:26 AM
86300zx
Feb 5, 2007 07:52 PM
Dutchrub03
Aug 8, 2004 11:45 AM
CWHammer
Jul 22, 2004 09:56 PM
Nick'75
Jun 16, 2004 03:45 PM
