AC change to R134A from empty
Hi guys,
87 ZX I have seen others ask this, but hope to get a real straight answer. There is no charge in my system i.e. warm air nothing close to cold coming form my AC. In fact, since I got the car 6 years ago, I have never used the AC. This being the case, is there anything I need to evacuate or are we rather certain nothing remains? If I can go straight ahead and load up the R134..is there a preferred kit you recommend? Am I correct in assuming the LOW side is right next to the Compressor and the HIGH side is at the Dryer? Any helpful hints are appreciated. |
Some things to clarify...
Originally Posted by Donn144
(Post 347376)
(Post 347376)
As for recharging with R134a... yes it's a straight forward process as long as you do it correctly. I've done ~10 conversions from R12 to R134a. I just use the screw-on Low & High port adapters but I remove the stock R12 system Schrader valves. The system must be vacuumed to remove moisture and atmospheric air. I use the Harbor Freight manifold gauge set and their pneumatic (compressed air) vacuum pump. Procedure: -Remove R12 system Schrader valves. -Replace with Low & high port adapters -Hook up manifold gauge set to both ports -Hook up vacuum pump & apply vacuum -Open both low & high port knobs -Watch pressure drop to at least -20in Hg -Allow vacuum to continue for ~5min -Close both knobs and watch gauges -Pressure should hold steady. If it drops, there's a system leak that must be fixed -After pressure test, system is ready to fill -Remove vacuum pump & hook up first can of R134a. If system has been empty, use a can with oil / conditioner -Purge yellow charge hose at the manifold to remove any air -Open low knob & you will hear the R134a flow into system -Slowly rotate can from straight up to upside down & back. This helps the gas & liquid flow more easily into the system. -Once the flow slows, start car with a/c off. -Turn on a/c. Compressor should kick on & continue to suck R134a into system -An empty system will usually take 2 cans. -When first can is empty (no longer frosty cold), close low knob, remove can, install new can, repeat purge -Watch gauges... fully charged system low side should be at 30-40psi, high side 170-200psi depending on ambient temp (hotter = higher pressure) -Check that the vents are now blowing ice cold air Done. |
Hey, Bravo Nismo PIck! Brilliant job, very well done. So clear! Love to see that! :006:
Hey have you thought of taking a management position at this web site? You'd be great at it! I'm definitely writing to the management for you! Cheers and thanks! |
Yeah all good tips nismopick , bit you might just suck it down and see if it holds , condensers are always a weak leak point. , see if the comp clutch lock or needs regapping, not that hard to replace the hoses and you can run a solvent cleaner through the lines
Whew..OK I have never worked on AC, so a little tentative.
I have no idea what is in the AC,,i.e. it never blew cold air as I can recall. Does this automatically mean I have leak? How else would the coolant get out? i.e where else did the R12 go? I am almost certain the compressor runs, the engine takes on the heavier load when I hit the AC button. Thx for the excellent instructions! |
