1984 ZX Digital dash
1 Attachment(s)
Need fuel level sensor for tank, have read of an upgraded 2 float unit but can't find it either.
Any help appreciated. |
NLA. You have to find a good used one or fix yours. I fixed mine by taking just the float out of one in the junkyard. The tangs on the float break off (four of them), corrode or lose contact. The are easy to work on. Dont but the whole thing from the JY. Just remove, dissemble and check the float first. The first one I bought, the float was bad. Lesson learned. Digital and analog both had can style. The floats are all the same, but the center rail has different resistantance between analog and digital. Additonally, they charge you next to nothing for the float and more for an entire FLSU, I’m cheap too. |
1984 digital fuel level sensor in tank
Originally Posted by JSM
(Post 347605)
You could install it wrong yes. It is pretty obvious when you look at it closely. This is is the top. 2 in the middle and 2 on each end. https://cimg3.ibsrv.net/gimg/www.zdr...020aaa7ba.jpeg |
(Post 347608)
Not to sound sarcastic, but if the float has the tangs in a certain spot wouldn’t you think the rail would too? Take it apart you will see. 😀 |
