Go Back  ZDriver.com > Cars > 300ZX (Z31) Forums
84 NA Auto has fuel and spark, wont start? >
Old 04-29-2018, 08:53 PM
Humvees2Zs's Avatar
I have an 84 300zx, my pops left it sitting for a decade, and Im tryin to resurrect it. Ive got a new battery w/ 525 crank amps, new spark plugs(and dropped mystery oil in plug holes) new fuel pump, and fuel showing on the return line past the pressure regulator. Got good spark, tested only one plug, have tried cranking w/ MAF sensor connected and disconnected, When I crank, it sounds dry, like no fuel gets into the cylinders, and the ECU reads code 31. Any ideas would be appreciated! Thanks gents!
Humvees2Zs is offline
Old 04-29-2018, 09:08 PM
Humvees2Zs's Avatar
Sorry, forgot, it will fire with ether into air intake.
Old 04-30-2018, 09:13 PM
Stop with the starting spray , use a squirt bottle with gas ,carefully ,only
starting spray is only for exterme cold carbed cars
got injectors clicking? check compression , how fresh is the gas? You want it oiled good before it fires any way I pull 2 plug wires on a start up
86tcoupe is offline
Old 05-01-2018, 05:37 AM
Cobalt60's Avatar
If it starts with ether in the intake then it's probably not getting fuel otherwise.
Something between the fuel rail and the cylinders is not functioning. Fuel injectors?
Cobalt60 is offline
Old 05-01-2018, 05:39 AM
JSM
I’m going with injectors plugged. Like above if they don’t click, open and close, you won’t get fuel. I just went through this with an 87 NA. Had to clean them one by one and jump them to get the, to open and close. Car on sat for about 2 years.
JSM is offline
Old 05-01-2018, 02:46 PM
Humvees2Zs's Avatar
Okay, thanks for the input guys, Ill pull the injectors and get em cleaned up.
Old 05-02-2018, 08:45 AM
They wont pump out the right fuel no matter how clean if the pump is weak ,check fuel pressure
I believe I got the last fuel pump assy. For z31, Usually they are cleaned by running the engine with a tank cleaner
86tcoupe is offline
Old 07-08-2018, 07:27 PM
Humvees2Zs's Avatar
I was doing some rust abatement on the battery tray, and pulled a couple bolts off the side of the tray, what looks like a fuse box came out from under the tray. Im having trouble identifying this component, anybody know what this is?
Old 07-09-2018, 04:48 AM
JSM
From under the tray? There is a black box on the side that has three fusible links in it. Got a pic?
JSM is offline
Old 07-10-2018, 09:05 PM
Humvees2Zs's Avatar
Y
Old 07-10-2018, 09:07 PM
Humvees2Zs's Avatar
Sorry, yes under the metal battery tray. And if this is fusible links, would one of them be the one that goes from the ECU to the injectors?
Old 07-11-2018, 04:36 AM
JSM
That is the fuel pressure regulator module.
300zx Parts For You webpage
have you down loaded the FSM from Xenon? They have a pretty decent diagnostic pages.
XenonZcar.com Z31 1984-1989 300zx Reference
JSM is offline
Klik
08-01-2016 09:57 AM
Fairladyz1990AF
04-24-2014 04:15 PM
Colorado280zed
03-07-2014 11:02 AM
tc300zx
20
05-23-2007 02:47 AM
Tymerider
01-07-2004 07:57 PM
Quick Reply: 84 NA Auto has fuel and spark, wont start?
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
