ZDriver.com
-   300ZX (Z31) Brakes, Wheels, Suspension and Chassis (https://www.zdriver.com/forums/300zx-z31-brakes-wheels-suspension-chassis-76/)
-   -   !Vibration in steering wheel~ (https://www.zdriver.com/forums/300zx-z31-brakes-wheels-suspension-chassis-76/vibration-steering-wheel%7E-37080/)
Evan Faris 02-14-2013 06:32 AM
The past few days i've noticed vibration in the steering wheel in my 88 z31.. When I accelerate, it vibrates somewhat heavily. When I brake, it vibrates but I heard my rotars might need turned? Anyways, help! Thanks:icon_super:
NismoPick 02-14-2013 07:27 AM
Warped rotors only vibrate the steering wheel when you are braking.
Get your wheels re-balanced.
And click: https://www.zdriver.com/forums/tire-...rations-36311/
Evan Faris 02-15-2013 08:01 AM
Ok. Can you switch tires all around when you want? I'm wanting to switch like the back left tire with the front left? My back rear tire is getting bald in the inside of the tire and I figured that I would switch both rears and same with the front. Will that throw the steering off?
Btw, my rotars are all new around as of 3 months or so ago.. I still have a warranty for them..
NismoPick 02-15-2013 08:49 AM
Quote:
Quote:
Your rotors are not the problem for the acceleration shake, and unless you've been riding your brakes, or got them REALLY hot, they are not warped, and are not the brake shake problem. So, have you been riding your brakes? Do you drive down a lot of steep streets?
Quote:
Yes.
As long as the both L & R are the same size, it won't throw off steering.
As I stated before, get them re-balanced. If you hit / nudged a curb, pothole, or bump, you could have lost a wheel weight, causing the shake. Also make sure all lugs are tight.
Evan Faris 02-15-2013 04:19 PM
ok and my rotars vibrate when i slow down.. the steering wheel shakes when i brake.. when i accelerate, the steering wheel shakes.. my friend who has 4 Z's says my tie rod ends might be changed?
NismoPick 02-15-2013 08:50 PM
Quote:
Quote:
Quote:
Speechless
turbotim 05-03-2013 05:22 AM
maybe u got some worn out bushings also
Copyright 2000 - 2014 ZDRIVER.COM All Rights Reserved.
