Rear Camber Perfection...
Old Dec 20, 2008 | 08:45 PM
johnZboy's Avatar
Distinquished Guest
Talking Rear Camber Perfection...
I'm using coil-overs on my z31. I can about "drop the bottom" out of it, if I want. I don't really want to drag the floor pan, but, I do want it to sit as low as practical.
Prior to the coil-overs I ran the Eibachs, and, even then my rear camber was horrible. The wheels and tires were tucked so far in the up position only about 35% of the tire was in contact with the road surface. Bad mojo when applying some power.
So, I fixed it...
I lowered the outer mounting hole for the left control arm 3/4"...
I lowered the outer mounting hole for the right control arm 1 1/4"...
I had to get a little extra because the camber was 1.50 degrees worse on the right side. This required adding some extra material to the mounting tab.
That took care of it...
0.50 degree of negative camber on each side...
Old Dec 20, 2008 | 09:17 PM
Gorgeous! Any thoughts on why the right was so much farther out? Tweaked control arm?
Old Dec 20, 2008 | 09:23 PM
johnZboy's Avatar
Distinquished Guest
Thanks... Don't have a clue why there was such a difference. There was no visable damage, and, nothing appears to be out of whack. Just a Nissan.
Old Dec 20, 2008 | 10:58 PM
lol i love the original low cut haha... looks dangerous
Old Dec 21, 2008 | 04:59 AM
KasbeKZ's Avatar
Pr0n Addict
awesome. your updates never fail to impress!
Old Dec 29, 2008 | 08:38 PM
entropy31's Avatar
The Cake Is A Lie!
nice! best rear camber iv'e seen on a z31.
Old Jun 8, 2009 | 09:34 PM
SloppyGoat's Avatar
Nice job. I'd like to get all the camber out of mine, but it really doesn't wear as badly as I thought it would. It's nothing compared to the inner tire wear I had on my 240SX anyway. I don't plan on lowering my car though.
Old Jun 8, 2009 | 10:26 PM
why not just make a new mount with little ticks to measure the camber?
stevek247
Feb 28, 2013 09:36 AM
Turbo86
Mar 14, 2007 08:40 AM
thxone
13
May 12, 2006 12:18 AM
rob209
Apr 23, 2006 10:14 PM
85TurboZ
13
Mar 6, 2004 04:26 PM
