power mirror controls
Old Oct 10, 2005 | 02:13 AM
Velox ZX's Avatar
From: I'm located in the more southern local... Jackson, MS.
I haven't found them very important, but I thought about it tonight, and it's one of many things in my Z that just doesn't work... I've always been used to adjusting mirrors by hand.. if someone can help me figure out how to make mine work again, I'd appreciate it.
JD
Old Oct 10, 2005 | 06:00 PM
AZ-ZBum's Avatar
first, make sure everything is plugged in.
Old Oct 10, 2005 | 07:39 PM
Velox ZX's Avatar
Everything is (yes, I've already removed the center console, and checked the wiring harness through-out, they haven't worked since I've gotten the car. What next?
JD
Old Oct 10, 2005 | 09:09 PM
craZed's Avatar
This would be a good time to check all your fuses and replace the blown ones
Old Oct 11, 2005 | 12:19 AM
SloppyGoat's Avatar
Break out the multimeter and start checking for voltages and continuity. If it's not fuses, that's about the only way you're going to figure out what's going on.
Old Oct 11, 2005 | 01:19 AM
Velox ZX's Avatar
Well... I went through the fuse panel and checked all the fuse slots, the empty slots have no contacts inside them, for my vehicle wasn't optioned with them. Though it doesn't help that I don't have an owners manual, or fuse panel door. I suppose you're right... I'll have to get out the voltmeter and start checking...
JD
Old Oct 11, 2005 | 01:34 AM
AZ-ZBum's Avatar
you said nothing about removing the door panels and checking the connections there.
Old Oct 11, 2005 | 03:39 PM
Velox ZX's Avatar
Well, the only connections that I dissconnected in the doors, are the little red "door open" lights. those are plugged up now, I have not removed the mirror fixture, because I don't want to break it. Next step?
JD
Old Oct 12, 2005 | 12:04 AM
AZ-ZBum's Avatar
you have to disconnect the wiring before you can remove the mirrors. try looking
RSuave08
Feb 9, 2014 02:17 PM
SanMarcosZfreak
14
Nov 7, 2005 05:31 PM
Fast240Z
May 19, 2005 03:52 PM
zeefogey
Sep 29, 2004 07:30 PM
Dolomite
May 27, 2001 06:06 AM
