Leaky T's
My t-tops leak whenever I go through the carwash, I have a feeling I'm not the only one with leaky t-tops. Its fine in the rain, but whenever pressurised water hits it, water just pours in.
How do I fix that? Is it possible? I can see a big gap in between the windows and the rubber on the t-tops where they meet with the windshield. But the rubber doesnt look rotted or anything. |
remove the door panel and toward the top of the window are little plastic things that prevent your window from going to far up.chances are over time the rolling up and down of the window has lowered them on the bolts.(with your windows down) loosen the bolts on these 2 plastic things slide them up a little MAKE SURE your door is closed and roll your window all the way up.adjust them as needed,the reason i say close your door then roll your window up is becuase if you have it all the way up and shut the door your window could hit the car and crack/break wich would be very bad.
if your need info on how to remove the door panel just ask. peace brother! |
| All times are GMT -7. The time now is 09:59 PM. |
