Brakes messing with engine?
Old Jan 1, 2006 | 01:51 PM
Ravin's Avatar
Question Brakes messing with engine?
I have a puzzling problem. I have a 84 turbo Z, my brakes seem to be messing with my engine somehow. In the mornings or after sitting for a few hours, when I go to drive the car, I have to pump the brakes before I start going and it takes about four pumps of the pedal before the brakes work. Then when I'm driving it usually takes one pump in order for the brakes to work well.
The really puzzling part is that when I pump the brakes the engine idles lower and lower with every pump. I have no idea what would cause that. I have just started looking into it to find the problem, if anyone could point me in the right direction I would appreciate it.
Right now I'm just going to start looking through my haynes manual to see what I can find.
Old Jan 1, 2006 | 01:55 PM
AZ-ZBum's Avatar
master cylinder is leaking or brake booster is shot.
Old Jan 1, 2006 | 11:32 PM
loosenut's Avatar
i 2nd the booster is bad
Old Jan 2, 2006 | 06:52 AM
CanyonCarver's Avatar
Jack Of All Trades
or both........... you prolly have a fluid leak that causes the system to lose pressure and a vacuum leak in the booster or the vacuum line to it. Fix the fluid leak first.
It's normal for the idle to drop a little when you pump the brakes. The motor shouldn't almost die tho.
Old Jan 11, 2006 | 02:14 PM
WolfMan's Avatar
I 3rd the booster, and most certainly a leak.
When you pump, if its a vaccuum leak, that could cause the engine to distort. Just do a good check over under the hood, and park on a level surface and look for shinny spots in the mornin.
good luck
zordietrying
Oct 30, 2011 05:35 AM
87z
Oct 9, 2011 11:33 AM
raythenegr0
May 28, 2008 04:45 PM
DatsunKid
Jan 3, 2008 05:05 PM
WildmaN
Nov 18, 2006 12:30 PM
