When my Z gets cold it won't run!
I have a 1983 280ZX non-turbo automatic. When it stays outside in cold weather it barely starts, sputters, smokes black like crazy and fouls the plugs. During warm weather it runs perfectly. If you start off warm and drive in cold, no problems. We've replaced the AFS but didn't change anything. Any Ideas???
Have you checked the CHTS, thermotime switch, cold start valve, and air regulator? Those are the 4 main components in cold starting.
I don't know what the CHTS so no we haven't replaced that. Tech says it's not a thermotime sensor becasue it doesn't do it by engine temperature but outside temperature, we replaced the MAF, and no on the cold start valve. I may not have been clear with my description so let me start again. If it is warm or sits inside a heated shop it starts and runs perfectly even if it is cold outside. If it gets cold it's hard to start, runs so rich it smokes black, and fouls the plugs. Over 60 degrees and it is perfect.
Originally Posted by venomgg
(Post 306508)
(Post 306508)
(Post 306508)
It sounds like you are doing this w/o a manual, so you should either buy a Haynes manual, or download the FSM for free at www.xenons130.com/reference |
Had it in the shop with a supposed Z magician. He thinks it is a bad connection somewhere in the body! Can't imagine that and didn't want to just start replacing parts. I ordered all of the above and will keep you posted. Thanks for the help!!
(Post 306511)
Why not test the sensors so you can pinpoint the problem, and save yourself a headache and some $$$ ? |
... and if the connector or plug is bad or dirty replacing the part isn't going to fix the problem (unless it's the sensor side of the connector but that's the hard way to fix it when cleaning the connector on the sensor might work)... all of the above are in the EFI harness - not the body harness so I'm not sure what
