What kind of BS is this!
well. i spent about an hour and a half connecting a speedo cable to my dash cluster. I go out to test it. and the neddle goes BackWards! What the Hell.
Make sure you're car is in a 'Forward' gear! ;)
it is, i was goin at least 30 just goin down the road.
wow!!! that's one problem i have NOT had!! the ONLY problem i have not had yet.
how is that even possible? The "shaft" inside the speedo connects directly to the "shaft" in the tranny correct. And that is mitregeared to somethign inside the tranny. (Thats the way most work) Aw jeez there is blood coming out my nose.
Speedo Miles are jammed. They don't spin, and i can't even reset the trip meter. Time for another speedo.
Flip The Cable Around, You Have It In Backwards. Lol
damn i was gonna say that ^^^^ i guess i can still laugh.
Blaaaaa!. Thought this would fit the title. Last night i had some freinds over. i started it up. and moved it around. reved it a lil and just let it idle. I love the way it makes the car rock while it's idleing at 1K.(and it has good mounts) It's probly the fact that 2 or 3 cylinder's are burning coolant and gas. While i was siting there idleing, i reved it. Of course she was smokin. and ppl thougth i was spraying for skeeter's. I noticed a new smell. and a much thicker smoke. i looked down and the warning box was flashing the water light. Since i was only about 50 feet from where the Z sits. i parked it. lifted the hood. I thought that maby my leaky WaterIntake gasket(it leak's) finaly let loose. Nothin was wet. I opend the radiator cap(was warm, but not hot) i heard a gurgaling noise as soon as i took cap off. I looke din it, and i saw All the water just disaper. I was like WTF. Then i heard what sounded like a waterfall. All the water drained out the driver side of the block out of a freeze plug. Found out that the frezze plug installed only 3 months ago, was not installed right. it was taped in. and she did not tightin up the bolt on it. I found the freeze plug, Some how it stayed in the engine bay, and was undamaged. and i could see a ring in the rubber where it had been siting in the block. it was not even installed half way in. Thank God this happed 50 feet from my drive way, and not goin down the road, and a hell of a tiem to do it too, since the head is comin off tomarrow. that will also give me lots of room to install it right. Nothin overheated. or was damaged. Just thought i would share it.
damn thats good luck
good luck? lol i thinkk its good bad luck.
yeah I'd say it's borderline. Good that it didnt happen on the road but I dont know if it can qualify as good luck since it happened at all :rolleyes:
Regardless, it's good that you caught it fubar :) |
yeh. i ain't mad at all. nothin was damaged. and won't cost a dime to fix.
the water and coolant. or do you make your own with your own home grown chemicals :D
That's great to hear Fubar, you got lucky, for sure. That would have been a disaster down the road. I have never had to deal with freeze plugs on any of my cars yet.
freeze plug ain't somthing that just goes out. seems i alway's get the werid problems. what the hell.
