ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Turn signal light question (https://www.zdriver.com/forums/280zx-s130-forums-77/turn-signal-light-question-39567/)
ohsemix Apr 22, 2014 03:04 PM
Ok so i checked every wire under the steering column that goes to the turn signal and none get any current my hazards dint work at a point but i cleaned the inside and they work now. But my turn signal flasher and the switch dont get current. I checked my fuse box switched my fuses but the turn signal fuse is the only one not getting current even after switching them. I checked the wiring diagram but it doesnt show the fuse box.So i would like to know were the fuse wires get current from and i would also like to know the color for the turn signal fuse wire coming out of the fuse box.
PredatorZ Apr 22, 2014 04:01 PM
Fusible Links
When all your fuses appear good, then you need to check your fusible Links, they are in a box near your battery, your FSM will show you exactly where. Fusible Links are made of a lower gauge wire than the circuit they are protecting, when you experience a high current on a circuit the Link will melt. The plastic cover on the wire is designed to not melt when the wire does, so it may appear intact, best to check continuity with a meter or test light. here is a link to what you may need, not all local parts stores carry the Fusible Links.
Motorsport! Fusible Links & Covers - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
NismoPick Apr 23, 2014 10:36 AM
The turn signals won't work if the hazards switch isn't COMPLETELY off. Check the hazards switch...
ohsemix Apr 23, 2014 01:28 PM
i have checked all the links and relays in the engine bay with a test light about a week ago but that wasn't it all of them work.Nismo what do you mean the hazards need to be completely off i disconnected the hazard switch because it got in my way but im not sure if that thats completely off
ohsemix Apr 23, 2014 04:42 PM
ok i fixed it i cleaned the grounds in the engine bay and i forgot that the hazards need to be connected for the turn signals to work but when i connected the hazards to checked them the signal lights worked so i guess it was the ground on the block that we painted and was also dirty
ohsemix Apr 28, 2014 01:47 PM
well they stopped working again lol what could have caused it to stop?
borini63 Apr 28, 2014 03:04 PM
Wigggllle the Hazard switch back and forth slowly until you get signal!!See at what point your signal works in the hazard switch and then leave it a lone,don't miss with it.It's a 30+ years switch.....
ohsemix May 1, 2014 04:32 PM
lol ill try it its so delicate
PredatorZ May 1, 2014 05:43 PM
worn out
Those switches are the source of a lot of problems, the contacts become worn and corroded and stuff stops working. Taking them apart and cleaning will help.
ohsemix May 3, 2014 03:35 PM
hey predator z your first post may be the issue after all i didnt notice till now but one of the fusible links is toast so ill buy one soon
ohsemix Oct 8, 2014 02:18 PM
so i made a link out of regular wire and it burnt up again. Its the ACC fusible anyone know what might cause this i dont have power anywhere after it burnt out
NismoPick Oct 13, 2014 12:27 PM
Using normal wire in place of a fusible link is a quick way to see your car go up in flames... I'm surprised only that replacement wire burnt up. Must have been a small gauge?
Look in the FSM and check all components that are powered by that fusible link.
