turbo J pipe
has a opon port on top where does it go and can I block it off. Looks like a hose hooks on.
do away with it or what? I tore my car 3 years ago and don't remember what it does. kenny and jim |
Goes to the 5-way metal splitter...
See my 2nd pic in this post: https://www.zdriver.com/forums/showp...&postcount=156 PS... where's your HAYNES MANUAL? |
can i block it off
and if i do, will it help or hurt, sorry but the pics, i cannot see where it goes. I cleaned up the manifold and don't have that stuff on the intake topside.
I still have it, do I need to reinstall this? I took it off to clean up the intake manifold, fubar said I didn' need this stufff. I still have everything I took off cataloged. thankx kenny and jim b |
is it necesary
(Post 266589)
See my 2nd pic in this post: https://www.zdriver.com/forums/showp...&postcount=156 PS... where's your HAYNES MANUAL? kenny and yes, jim bean is still here. |
Are you running the stock EFI?
The thing on the left of that picture that connects to the TB is the Idle Air Control, which if you don't have will really suck on cold starts in the winter months. |
thanks NismoPick
that picture is worth a thousand words.
a clear picture that shows most of what I need to know. Are there any benifits for leaving the j pipe pluged? Looking a a spare turbo intake manifold I see it goes to: 1. ACC valve. 2. valve on the intake called the F.I.C.D can't find out what that does... 3. Vac corntrol valve? whats that do? It' goes to #4 runner before injector. 4. Air Regulater 5. Heater housing. what are the negative benifits of leaving the pipe pluged? running jwt package. thanks kenny. |
yeah it goes to the AAR
Originally Posted by captken
(Post 266627)
negative benifits
There is no real benefit (other than looks) to remove it.
Asswipe
(Post 266638)
negative benefits? you probably voted obama... |
(Post 266606)
want to clean up manifold and increase performance. If is is needed, I'll put it back on. Learning here. Want the best for my buck
