turbo j-pipe....
Old Jan 18, 2008 | 07:36 PM
DriftZ83's Avatar
turbo j-pipe....
i just noticed that my j-pipe doesn't have the nipple on it in the middle.... what is that for and why do some have it and some not?
Old Jan 18, 2008 | 07:40 PM
a plastic piece sets on the nipple and holds the lead in place that runs from the coil to the distributor.
I thought all of them had it. Yours may have been removed by a previous owner.
Old Jan 18, 2008 | 07:49 PM
DriftZ83's Avatar
no mine NEVER had anything on the j-pipe... and it's the big 1/2" pipe nipple in the middle that has a hose on it and goes to 3 others. i am only the 3rd owner and i know the last 2 so for sure NO.
Old Jan 18, 2008 | 08:25 PM
Es de uh.... maybe you should post a pic of this nipple.
Old Jan 18, 2008 | 08:30 PM
DriftZ83's Avatar
i just took this off another post... it's at the bottom of the picture on the j-pipe and has a hose comming off of it. https://www.zdriver.com/forums/280zx-s130-forums-77/air-fuel-issues-24739/
Old Jan 18, 2008 | 08:33 PM
This??? (see yellow arrow)
It's for the air regulator / AAC. If you don't have it, you've prolly got idle probs.
Old Jan 18, 2008 | 08:39 PM
DriftZ83's Avatar
yes that... my car does NOT have nor EVER had that. but i DO have an AAC valve and i do NOT have idle problems. i'm just curious cause i got another j-pipe off ebay and it has that nipple.
Old Jan 18, 2008 | 08:40 PM
Post a pic of your engine bay...
Old Jan 18, 2008 | 09:04 PM
DriftZ83's Avatar
duh.. i'm retarded!! i guess i've always looked past that... i've NEVER noticed that on mine before and i was work'n on it tonight! lol sorry
Old Jan 18, 2008 | 09:07 PM
And that's the end of that chapter.
PS... clean engine bay!
Old Jan 18, 2008 | 09:14 PM
DriftZ83's Avatar
lol figured that! thanks i try to keep it super clean... thats why the tb swap the greddy pop-off valve... the turbo timer. the extra gauges. i just like to add to the already ZWEETNESS that is the ZXT!! so if i get rid of the AAC setup with the Z31 ecu i can remove all that?
Old Jan 18, 2008 | 09:19 PM
All of that? Like the AAC and EGR...
Old Jan 18, 2008 | 09:21 PM
DriftZ83's Avatar
the AAC and the 4 bigger hoses that go to the j-pipe.. the tb... can remove the EGR?
Old Jan 18, 2008 | 09:27 PM
It's all been covered in the Z31T ecu upgrade threads. And you can't get rid of all of those hoses because you still need the j-pipe to connect to the air regulator.
Old Jan 18, 2008 | 09:30 PM
DriftZ83's Avatar
not if i remove it right?
Old Jan 18, 2008 | 09:32 PM
Uh... do you know what it does? Can I remove the crank on my motor cuz I don't want it?
Old Jan 18, 2008 | 09:45 PM
DriftZ83's Avatar
i was talk'n about the AAC... i thought alot of people have been removing them? i'm confused lol
Old Jan 18, 2008 | 09:49 PM
You can remove the AAC (might have idle probs after) but that 4 way (really a 5 way) hose splitter connects the J-pipe to air regulator, so you'll need to keep a line between them.
Old Jan 18, 2008 | 09:51 PM
DriftZ83's Avatar
what exactly does the AAC valve do anyways?
Old Jan 18, 2008 | 09:52 PM
AAC = Auxiliary Air Control. It controls idle.
Old Jan 18, 2008 | 09:54 PM
DriftZ83's Avatar
gotcha! thanks
Old Jan 18, 2008 | 11:26 PM
duowing's Avatar
NisTuner
If you remove all of that, at least leave the air regulator and just run hose from the J-pipe to the air regulator.
captken
Sep 24, 2015 04:54 PM
soysauce300zx
Dec 26, 2013 09:32 PM
PeteZ Racing
Jan 20, 2006 08:55 AM
Chris91se
Dec 8, 2003 12:47 AM
