Try This Question Again
Old Mar 14, 2005 | 05:34 AM
BJ BISIG's Avatar
I Need To Know A Good Way To Figure What Size Spacers I'll Need For The Rims I Want To Use. 16x8 With 6" Back Space. I'm More Concerned With Clearance On The Front Struts.
So Far It Looks Like 1.25" Will Work Well On The Front & Rear.
Old Mar 14, 2005 | 11:25 AM
RodMoyes's Avatar
Doesn't post much...
16x8 is a very wide wheel for that car. I'm running 17x7 with a +40 offset, 235/40zr17's and a 1.25 inch adapter... I have about 4-5 mm's clearance from the strut at best. I'm thinking 1.25 aint gonna cut it for your 16x8's. But it depends on the offset I suppose. If you get it far enough away from the strut then it only has one other way to go... outside the wheel well. I'm not into the look of having your wheels stick out, but....
Rod.
Old Mar 14, 2005 | 12:38 PM
icice9's Avatar
Super Siver & Black Stud
your gonna need more than 1.25" more like 2.50"
Old Mar 14, 2005 | 04:59 PM
theramz's Avatar
I have a present for you...
Maybe this will help. Hubcentric adaptors are a must!
Old Mar 15, 2005 | 03:41 AM
BJ BISIG's Avatar
Thanks!
THERAMZ
thats the info i was looking for. thanks for your time, i might get out and mess with it this weekend.
have a good day. BJ
Old Mar 15, 2005 | 08:06 AM
280Z4ME's Avatar
If you have a Les Shwab near you they make a 16 and 17 for the Z without using spacers.
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
