Time for some progress!
Old Apr 22, 2008 | 06:47 AM
dapper189's Avatar
Ok so i've had my Z since january of '05 and im finally getting around to working on it. here's whats going on.
Here is my intake minus the stock fuel rail.
There were so many brackets and bolts, i didn't want to have to take apart the front cover, so yeah i borked the lines. I figure i can just run FI hose to it later?
Here's the stock rail minus injectors. I was going to try and get a pressurized rail system from Palnet but i already have 6 good injectors on stand-by so ill just try those. Should i soak them in trans fluid overnight though? I've heard of injectors drying out..or is that a myth.
Im guessing that's the fuel pressure regulator there. I'll be replacing that...any suggestions?
Just a couple of pics
Old Apr 22, 2008 | 06:53 AM
Oh man... that takes me back. My Z looked EXACTLY like that 10 years ago ( except it looks like mine had more rust ).
And you didn't need to kill the fuel rail... just one bolt on the right side of the head, and remove the upper pulley on the front. You get to replace the rail now.
Old Apr 22, 2008 | 07:56 AM
dapper189's Avatar
I should jsut be able to use compression fittings and run line to it though right?
Old Apr 22, 2008 | 08:14 PM
lww's Avatar
lww
Head Muckraker
Yes, but I would cut the ends off clean and then flare them so the fittings seal well.
Old Apr 23, 2008 | 07:37 AM
dapper189's Avatar
well of course...does any have any experience with line of this nature:
http://www.jegs.com/i/JEGS/555/63034K/10002/-1
would it even work?
Also, i know its kinda redneck but ive been thinking about building a fuel rail out of T-blocks, with barbed connectors to each injector, so i can use my stock replacements for now, and hard line in between each T-block, and gauge too. Would anyone else be crazy enough to try this?
Old Apr 23, 2008 | 08:09 AM
would it even work?
$83 + shipping??? For $100 you can get a Pallnet or JSK fuel rail that will actually look nice.
What kind of T-blocks? And yes, that is reck-neckish, and the wrong way to do it. It's usually better to fix mistakes with PROPER remedies.
Old Apr 23, 2008 | 09:00 AM
dapper189's Avatar
Well i meant to use the line instead of hose since i borked the line on the front of the engine, and it doesnt have to be that actual line, i just thought line looks better than hose. To give you an idea of what i was planning....
Something along these lines. I'll price it out later.
Old Apr 23, 2008 | 09:09 AM
^^^ Just an fyi... the FPR goes AFTER the fuel injectors (where your "fuel pressure" drawing is). It wouldn't do much good before them. Switch the fuel pressure gauge & FPR... then you'll be good.
Old Apr 23, 2008 | 09:27 AM
dapper189's Avatar
sweet, thanks, I'll post pricing then after i get it ill post pics.
Old Apr 23, 2008 | 11:41 AM
dapper189's Avatar
As pointed out earlier, i had my reg and gauge reversed, so here is the same idea..corrected.
Old Apr 23, 2008 | 02:16 PM
duowing's Avatar
NisTuner
I think it ran me about $130 for a fuel rail and gauge from Pallnet.
Your ZX, looking a little dirty, but it looks clean. Is it in decent condition?
Old Apr 23, 2008 | 06:26 PM
dapper189's Avatar
over all, yes, its in fair-decent condition, ive seen 10 year old cars that are in way worse condition thatn a 28 year old car ya know....after i get it running ill do a post about all the flaws it has cosmetically. and yeah it sits in my garage and it has a broken door and window so i clean it once a year and then it sits and all kinds of leaves and dirt gets in my crappy garage...id like to refi my house to build a new 2 wide 2 deep garage..we'll see.
Old May 1, 2008 | 06:25 AM
dapper189's Avatar
Ok, so a co-worker of mine, her husband was a machinist in the navy and she asked him for me if he could fab up a fuel rail. Since i have barb type injectors and very little $$, I designed a rail that he could make utilizing what i already had. Below is the design I submitted this morning. Thanks to the tips I got from Nismo and the sticky article about cleaning up your intake here is what i came up with.
Ill post pics of the actual rail when i get it.
Old May 1, 2008 | 08:32 AM
SpeciallySpiked's Avatar
I'm a Registered User!
You should learn some CAD if you are going to be fabricating stuff up in the future.
I'm not sure if you can pull it off, but AutoDESK is allowing "students" to download autocad 2008 for free
www.students.autodesk.com
Just worried there will some mistakes from confusion reading plans and it takes less time woot!
Old May 1, 2008 | 09:55 AM
dapper189's Avatar
Oh, ive got it, and im 1 class away from my certification in it, but for all intents and purposes paint is faster and easier to manipulate, and a jpeg is so much easier to transport and swap between different computers and programs. Especially when you are making diagrams at work on your lunch break
Old May 9, 2008 | 08:53 AM
dapper189's Avatar
Update 5-9-08
Should have the new rail monday. Ill post pics that night. Gotta wait till next payday though for the install
Old May 13, 2008 | 05:34 AM
dapper189's Avatar
The rail is delivered!!!!!!!!!!!!!!!
My rail came in last night. Its pretty sweet..a little heavier than i wanted but its build out of hydraulic stock..i guess the guy thought it needed to handle like 500psi or something like that. Any how i have pics below and then a few question related pics..advice needed. Thanks
So ya, thats the rail.....below are some pics of some lines (and i know chiltons is bad but its all i have) that i cant find in my book.
there is that ancillary cooling line i read about blocking that off somewhere on here, but these come out of that block, and i saw in the chiltons that these are vacuum lines?? is that right? They go back to the water neck just right of the tensioner pulley.
there is that white plastic ?valve? with 3 barbs off of it. this is where those 3 lines come back to.
skittle
Feb 13, 2007 09:57 PM
DarrellBuddy321
Mar 31, 2006 03:53 PM
RPS13_GZ32
Apr 18, 2005 07:59 PM
Skully
Dec 7, 2004 03:11 PM
