Thermostat question
Hi, this is my first post and I need some help.
I bought a cheap not running partially disassembled '79 280zx 2+2, and I'm trying to assemble it. Cleaning the thermostat housing, I've found this: http://i59.tinypic.com/2jg7bd2.jpg As I've researched, the components are: Thermotime, Water temperature sender and Coolant temperature sensor. You can see in the picture that there is a broken (and missing) part, can you tell me if this is the missing part? Water temperature sensing switch http://i.ebayimg.com/t/ORIGINAL-ENGI...qN!~~60_57.JPG Thank you! |
2 Attachment(s)
It looks like you have it correct as far as I can tell. But I would like a second opinion before taking my word.
Pick up a free copy of your FSM at http://xenons130.com/ This is the key to unlocking every question you may have in your car. |
Thank you master, I do have the FSM but I was unsure about the part.
Now the challenge will be to remove the broken piece! |
Welcome to ZDriver!
Weld a bolt on the end and then your can back it out. Since the thermostat housing is aluminum, you can zap the heck out of it, the weld won't stick to the aluminum, but will heat it enough to loosen it. |
(Post 340741)
Welcome to ZDriver!
YA that looks right. different year cars sometimes moved sensors around on the housing, or the housing has block off caps if the car didn't have the option. The water temp sensing switch is used to operate the injector cooling fan i believe.
Originally Posted by Zuphoria
(Post 340771)
1 Attachment(s)
Injector cooling fan should look like this
Originally Posted by Tr0cken
(Post 340779)
Is the injector cooling fan the V-like thing that goes above the valve cover? Because I don't have it...
Originally Posted by borini63
(Post 340791)
I have one for sale if you are looking to buy,also I have the thermo housing pulled from 80 280ZX too!!!!
Does anybody know what is this? Can't seem to find it in the FSM.
http://i58.tinypic.com/15ocxfb.jpg http://i59.tinypic.com/23k8yv5.jpg |
Just a member of another forum that made this up, not sure how accurate, but seams reasonable, as throttle body had a heater in it as well.
http://www.renderanything.com/vehicl...gram_75-78.jpg |
Thank you very much Skully! This is exactly what I needed.
| All times are GMT -7. The time now is 02:13 AM. |
