Testing Oil Pressure gauge
Old Sep 18, 2008 | 01:11 PM
duowing's Avatar
NisTuner
is there a way to test the oil pressure gauge? I have put in a new oil pressure sending unit, but the thing still seems to act the same way. I don't know if there's a problem with the new sending unit or if it's in the gauge. Is there a way to test the gauge itself. I know with the temp sender, you can just ground the signal wire and watch when you switch the car ON, and the needle will make it's way to the other end of the gauge if there's a good connection.
Old Sep 18, 2008 | 01:31 PM
KasbeKZ's Avatar
Pr0n Addict
get an external mechanical gauge to compare it to. most mechanics shops will have them just for the purpose of testing when the gauge in the car can't be trusted
Old Sep 23, 2008 | 11:26 AM
vrocious's Avatar
go the same problem here, got a new pressure sender unit waiting to go on to see if that helps
duowing
May 9, 2007 11:47 AM
chukker
Oct 8, 2005 03:58 AM
Fast240Z
Sep 26, 2005 12:01 PM
TX_zx
Jul 12, 2004 12:15 PM
AllmyZs
Sep 17, 2003 11:29 AM
