Temperature gauge...
Old May 13, 2007 | 06:08 PM
n00blar's Avatar
So, I've been test running my ZX when all of the sudden my temperature gauge stops working. It used to work just fine, but all of the sudden the needle sits all the way to the bottom.
Is there an easy way to test the gauge? I don't know where to look for at this moment; all the sensors related to temperature are new.
Old May 13, 2007 | 06:29 PM
duowing's Avatar
NisTuner
I had the same issue with my temp gauge. It wasn't working. I pulled off the connector to it, not like the normal connector clip, it's one of those little round clips, and then stuck a little all metal screwdriver I had into it and touched it to metal on the body of the car. Turned the power to on and then the gauge went all the way up, so that told me the gauge worked. There must have been corrosion on the connector or something, because after plugging it back in it all works again.
Old May 13, 2007 | 06:38 PM
n00blar's Avatar
Ok, I tried to follow your instructions, but got a bit confused.
This connector that you're talking about, is it by the thermostat housing or behind the temperature gauge itself?
Old May 13, 2007 | 07:16 PM
duowing's Avatar
NisTuner
It's on the thermostat housing. I found this picture on a website, and this is on a turbo engine mind you, but these are the types of connectors I'm talking about.
Put like a nail or screw, something metal and long enough to touch the connector inside and then touch it to a bolt or metal part on the body to ground it. Then just put the key to the On position, no need to start the car, and if the gauge and wiring is good, the needle will go all the way to the other side of the gauge.
Old May 13, 2007 | 08:30 PM
n00blar's Avatar
Oh! I get it now...thanks, I'll give that a try
Old May 13, 2007 | 10:07 PM
they are called bullet connectors, those sender guages suck on these cars. ive got a thread started on hybridz to see if anybody has tried a different type of sender. like a ford on that has a threaded stud on it that a loop terminal can go on. i hate these senders!!!!
Old May 14, 2007 | 08:18 PM
ToxicZ's Avatar
rgr that. mine broke off last time I was workin on the car but I'm planning on doing nothing about it.
and liking it.
Portland 300zx
Oct 26, 2011 11:04 PM
awilkie
Jul 31, 2009 04:56 PM
3XAZOWNER
Jun 1, 2006 08:28 PM
alexander
Apr 29, 2003 08:18 AM
Ramen Sama
Apr 28, 2003 06:26 PM
