--TeAm NiGhT ShIfT-- at it again
well well ...we have a new car on the team ....old member new car lololol ...
this car was gutted strip of the stock KA , this last few weeks and now has a SR20DET ...just a few little things left and she will be up and running ... lsd install a small wireing issue front mount install and few little odd and ends ...... grays bro is really stoked on this one ...he pretty much had the same car befor this.. it was a red 240sx hatch ...he swaped shells becauce of body damage and police issues... also i got a helping hand from a few good team members to pull the motor and trany from my junker ....iam going to do a trany swap at some point :icon_hang: ...also iam slowly going to build a turbo motor from the bottom up from this block ....it will be a long term project ....however for now i must !!! ..clean and port this extra intake...i changed the trottle linkage on my 60mm trottle body ..it was very eazy not a hard fix at all.. so with this 79 intake ported and cleaned and the 60mm trottle body it should give it the extra kick im looking for .... i have a shed full of extra parts ... Need anything let me know ! I will take a look see , and see if i have it ... http://i16.photobucket.com/albums/b1...d/eb34d9ad.jpg http://i16.photobucket.com/albums/b1...d/4cf359f3.jpg http://i16.photobucket.com/albums/b1...d/2a68b201.jpg http://i16.photobucket.com/albums/b1...d/db6b94c9.jpg http://i16.photobucket.com/albums/b1...d/9aa859a2.jpg http://i16.photobucket.com/albums/b1...d/b41abfbf.jpg http://i16.photobucket.com/albums/b1...d/da481789.jpg http://i16.photobucket.com/albums/b1...d/93556b45.jpg http://i16.photobucket.com/albums/b1...d/faff9a81.jpg |
Looks Great !
Got the ebrake off of old blown yesturday ..and installed it today on the good black this afternoon....what a bitch that was ..after i got it all hooked up i pulled it up and the calipers locked up ...i got some spray lube and lube the springs and cables up in there really well ...i had to have a friend work the ebrake handle .. while i worked the springs by hand untell they came free ....it took a bit of work but i have a good working ebrake now ....stoked out :044:the hardest part of this was trying to get the old cable out .if you try to do this then this mite help you ...there is a little locking plate that holds the cable it has a notch in it .dont try to slide the cable out the side of this plate ...it wont go out that way ....if you line up the cable just right with the hole and push the cable back though the plate it will come out....
awesome. and with a working parking barke, your rear calipers shoud be adjusted now... so maybe your regular brakes feel more solid?
I swapped out my sticky parking brake cable. I used some penetrating oil on the four exposed ends and worked it back and forth before putting the cable in. (as suggested by L-DUB in a previous post) |
yes my brakes do feel a little better.... now i can feel them grab alot harder in the back now ....man i took her out for a little run ..it rained here today so there was a little water everywhere ..man O man SLIDE city ..my car is nutty half trottle drifts back and fourth for over a block ...so nuts ....auto rules.
now wit her lowerd she is a back and fourth moster eazy to control ..as long as you dont over power them and spin it all the way around your golden .. .i need LSD MY HOMIE GOT SOME MORE WORK DONE ON HIS 24OSX ..PICS SOON TO COME |
and here they are
http://i16.photobucket.com/albums/b1...NESRIDE003.jpg http://i16.photobucket.com/albums/b1...NESRIDE002.jpg http://i16.photobucket.com/albums/b1...NESRIDE004.jpg http://i16.photobucket.com/albums/b1...NESRIDE005.jpg tomarrrow or next day lsd install ...i forgot to take a pic of this kids lsd its a pretty sick , well next time :) |
i know a guy hear in town with a super nice ! 1996 240sx hes giving me his 60mm throttle body for free.. but hes wanting me to find him a " RB26DETT " complete for under 5,000 dollars shiped.. im trying to convince him to get a red top SR20 det ..
Tell him to get an L20b with dual sidedraft Webers... :D
bleach ..i need a LSD ...come on man ..i need to drive over there so we can go to a junk yard ......my rear diff is driping just a little bit ..it has alot of gross build up ..its time to Yank that baby and slap me in a LSD ..
.COME ON MAN ... I KNOW YOU GOT LIKE TEN STASHED AWAY..LOLOLOLOLOLOLOL J/K O YA ....I THOUGHT YOU WHERE GOING TO CHANGE MY NAME ....NiGhT ShIfT DrIfT |
no way man, I've been scouring the yards for an LSD with no luck. I have found a few 84-86 turbos...
and I've got about 10 turbo engines over here, but no LSD units... |
i had a small problem ..my volts gau was freeking out ...i took a trip to the zchat and then asked icice about what was going on ..He was right on..
The alt was bad ...golden grams swaped it out this afternoon and problem fixed THANKS MUCH ICICE FOR YOUR HELP ... Zchat rocks .......... 240SX UPDATE ...Its RUNNING ....lsd installed drive line and all the goods are back in ...she fired right up ....we had to find the auto trany cut out switch .. because he swaped the auto for many trany ..lololol ..but all is well in the 240sx world ... there is a little left on the beast but not much as soon as we can we will get some slideing pics of this beast ......a quick trip to the g yard for a manl trany mount and then a little fun time mabe ... |
I searched junk yards for 3 years... finally gave up & bought one on ebay.
ummm.... $700??? rediculous when you can get a brand new NISMO unit for $900. Those things used to go for $300-350 on eBay.. but not anymore
Went to a few junk yards today ...:( NO LSD ..but i found a intake from a 76 that looked in good shape NO RUNNERS stoked ....when i got home a friend of mine stoped by ..he said he has a 300zx turbo that is a junker in the backyard ..it mite have a LSD and half shafts he is going to a check it out for me and if its there then it well be really cheap ...i will post up when i know for sure ..:thumbsup:
I know a guy trying to sell a built rb25det running 400 to the flywheel for 8k shipped. I can give you his email if your friend's interested |
*whispers* 5 Speed is calling your name.....
all of the other members have a auto to manual converted car and lsd. Now it is your turn obi-wan |
yes young jedi ...i have now almost gatherd all of the parts needed for my 5 speed swap ....i still need to buy a tight clutch ..anyone out there have any good ideas on a realy good one then post me a link :) o have two clutch slaves that look ok.... if one works i will be golden ..if not i will have to buy one of thoughts two ...everything is layed out so almost time ....bleach any last thoughts ..i lost that email you sent with the pics...could you mabe send me them again and a little info ..i dont was to mess this swap up ....i will pm you my email ...
I dont' have the pic of the clutch line anymore. Its not too difficult. I just made two gentle bends in it. Hold it up near your firewall and see how it might unfold to reach across. Let the force be your guide.
You are going to need more than just the clutch and brake pedals. I heard you need the whole manual tranny pedal assembly as your auto won't have the brackets for the clutch pedal. I'll send my droid to fetch the parts from my junkyard. |
1 Attachment(s)
Here it is, the assembly above the pedals that holds the pedals. Your parts car may have this but if you don't have it anymore, I can send you this one.
man that part is nasty, and has no pedals, i got one too dude, 15 bucks. no rust either!!! you will need that swing arm assy. the auto one has no provisions for a clutch pedal
he already has the pedals from this 'nasty' part, and this part is free... delivered. that is, if he needs to use this rust bucket.
hahahahah sorry guys, always tring to make a sale to keep my z going!!!! not to insult or anything
looking under there in the moring but i think it has the the backet under there already ...i dont know for sure but i was under there befor and it looked like it had it already if not the one that is in my parts car is good i just took the springs and bolt out of it today.....i will let you know tomarrow when i start digging around under the dash....my plain is to install the pedals frist then move on to the the other stuff .....
man i am so unlucky i just found a lsd for 30 bucks at the junkyard.
