Take a look.. multi function swith
Old Feb 19, 2008 | 06:17 PM
BackHouseZ's Avatar
Ok so like you may already know my gauges on the Z don't work and my blinkers didn't either. So I took a look at the switch and as you can see is burnt. I have a new multi switch that I got at the junk yard for $10 50% off day good deal but anyway if i connect the new one to the old wire will it work or will it burn out my new switch when i connect the battery back up? And with the bent up part of the switch do you think that may have made a difference? As far as my Gauges are concerned. Do I need a New connector (will I Be at the bone yard again)
Old Feb 19, 2008 | 06:22 PM
KasbeKZ's Avatar
Pr0n Addict
tha's probably just from arcing. i'm no electonics expert, but i'd just make sure that the contact is good and use lots of electrical contact grease. check the fuse for that too if there is one. make sure it's the right strength
Old Feb 19, 2008 | 07:49 PM
I made a thread a while back about this common switch prob ( just an FYI ): https://www.zdriver.com/forums/showt...ght=headlights
Yes, you should get the female wire side of that plug too, and cut / splice it in to your wiring.
Sean Nugent
Mar 13, 2015 06:57 AM
PredatorZ
FS: 300ZX (84-89)
Aug 1, 2014 07:34 PM
JDM Z
Jul 14, 2011 08:59 PM
kuch73
Oct 30, 2002 01:45 PM
zamber
Feb 20, 2002 02:13 PM
