ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   t/b swap (https://www.zdriver.com/forums/280zx-s130-forums-77/t-b-swap-34902/)
ZXT83 Apr 13, 2012 12:35 PM
t/b swap
Im current doing a complete engine rebuild and would like to upgrade my throttle body. I would like to know the best motor to source one from. Im looking to go to 60mm, i know i can find one on a stanza, or an 80mm that would be compatible. The thing is i see that every one has wire throttle linkage, is it possible to swap one of these in but keep my stock throttle linkage? I will also deffinetly be port matching. Any input on the subject would be great. Thank you
ZXT83 Apr 13, 2012 12:38 PM
I didnt want to start a new thread for this, when i pulled my valve cover there was water in the head. Is this from a blown head gasket?
NismoPick Apr 13, 2012 12:49 PM
You want the tb from a KA24E / KA24DE / SR20DE. The KA24 has a cable throttle linkage that requires modification to work with the L28 throttle linkage. The SR20DE tb is already set up with linkage, just needs to be flipped. We've discussed the 60mm throttle body swap to death, so feel free to search if you need more info.
And remember that just adding a larger tb to the intake will do nothing but waste your time and $$$. You need to port the intake neck and use the turbo afm body to get rid of the bottlenecks :D
As for the water in the head... has the motor sat for a long time? Does it have any mechanical problems?
Lesnocker Apr 13, 2012 06:41 PM
Missing coolent? Fuel in the rad? Oil in the rad? Fuel in the oil? Water in the oil pan? There will be a mixing going on somewhere and your oil pressure gauge will be acting like its on crack. . . . Just did my engine swap over a bad head gasket . . . . And the car WILL be undrivable 5 miles tops before all water is lost and well the smoke will kill you by then ;)
PurePontiacKid Apr 13, 2012 09:16 PM
I had the 60mm on my car and I regretted it.
everything past about 75% of throttle did absolutely nothing. unless you do some serious work on the inside of the intake manifold, it just isn't worth it.
I had considered going back to stock TB, but just ended up swapping to carbs lol
mrprofile Apr 14, 2012 08:31 PM
it could be condensation in the valve cover, if you don't drive your car long enough to boil away that water it could build up, eventually causing sludge oil, which just means you should change your oil more often.
ZXT83 Apr 15, 2012 06:34 AM
The car has sat for two years now, As far mechanical problems the issue i have is that the car has zero throttle response, After putsin around for a while i finally got the car to idle properly but still no rev when push down on the throttle linkage.
ZXT83 Apr 15, 2012 06:35 AM
I did know you have to port match the intake mani to the t/b but hearing that it wont make much of a difference i might as well leave the stock t/b
