Swap engine or have it rebuilt????
Old May 1, 2012 | 09:19 PM
datsuns130's Avatar
I was wondering if I should get my car rebuilt or swap the engine out and put a n/a vq30 - I think that's the 300zx motor.. Need help lol
Old May 1, 2012 | 09:23 PM
Why........
Old May 1, 2012 | 09:31 PM
datsuns130's Avatar
why what
Old May 1, 2012 | 09:36 PM
#1: I keep deleting your post in the write up thread because it's quite obvious you didn't read it. Nor did you see this in your other post:
https://www.zdriver.com/forums/newre...reply&p=310018
Did you click on this link and read it before reposting your question?????
I hope we didn't compile that help thread for nothing...........
#2: WHY do you need to rebuild your "car" (I assume you mean "engine") ?
#3: It's a VG30 motor (there are actually 4 of them... VG30E, VG30ET, VG30DE, VG30DETT). None of them are a realistic choice for a 280zx chassis.
Old May 1, 2012 | 09:47 PM
datsuns130's Avatar
rebuild cause it has 300xxx miles and i thought it could be possible for it ..
Old May 1, 2012 | 09:57 PM
datsuns130's Avatar
or whats need to make my n/a to turbo??
Old May 1, 2012 | 10:05 PM
It is possible for it. It is it. What is it? It is it.... opps sorry just rocking out to some Faith No More...
This is the single asked 48.723 bazzilion times question on every Z car forum going. The L28ET is cheap and easy to swap almost to being a no brainer. If someone has to ask about how to get an RB26 to fit in it's probably not a project you're going to want to take on. An NA VG30E isn't worth swaping in. A VG30ET isn't a significant gain over an L28ET and way more custom modding. A VG30DE is a good but not worth while. Haven't seen a VG30DETT - seems like a lot of work when you can get 300HP from an L28ET with way less effort...
Old May 1, 2012 | 10:06 PM
Read about the L28ET swap.....
Old May 1, 2012 | 10:09 PM
datsuns130's Avatar
Thanks for letting me know..
Old May 1, 2012 | 10:10 PM
datsuns130's Avatar
Do u know where I could buy a l28et
Old May 2, 2012 | 08:07 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
Do u know where I could buy a lB2R8AeItN
Craigslist
Ebay
Even here on our own forums: https://www.zdriver.com/forums/sale-...ts-cars-35024/
Two turbo motors, two turbo transmissions, literally everything you need for the swap.
Old May 2, 2012 | 09:13 AM
ThaPimpShrimp's Avatar
lB2R8AeItN
I just had to say.. I legitimately "lol'd irl" when I read that!
Old May 2, 2012 | 10:47 AM
Search function is definitely free
Old May 2, 2012 | 10:49 AM
datsuns130's Avatar
ebay is wack *** **** real talk .. craiglist is lame too
Old May 2, 2012 | 11:09 AM
Well where else do you plan to get one. Can't find them anywhere else really.. gonna have one manufactured?
I'd go craigslist. There's a couple of them in my area right now actually.
Old May 2, 2012 | 12:15 PM
Apparently he wants it to magically appear in his garage.
Old May 2, 2012 | 02:31 PM
That's what I'm getting out of this thread..
Old May 2, 2012 | 04:58 PM
What I didn't see that option when I was researching! Got a link for magically appearing engines?
Old May 2, 2012 | 08:01 PM
Lesnocker's Avatar
Um your friendly local machine shop ! Drives me crazy hearing "dude its got XXXX miles" have you considered its got that many because its a hell of a motor? Next the 300zx v6 engines are like you telling us your putting in a power stroke desiel. Doesn't make any sence to go through the swap when 1200. Gets you a fresh 2.8? That um you can get 300k all over again. Lastly I got my turbo engine upgraded and rebuilt and every bolt in the car replaced body painted for $11764.78 lol first pick a budget and have some commen sence. Hey anyone know where I can buy a 460 for my tempo?
Old May 2, 2012 | 08:12 PM
Lesnocker's Avatar
Honestly I'm with my hermit !! In my mind the last true Z had a straight 6. Myself I wouldn't even want that 300zx series engines. Gives me that icky 3.1 / 3.4 GM vibes Granted People may hate me for saying that but I do recall they had they're fair share of known problems the T/T well you may just want to save money and buy a 370z once you drop a turbo.
Old May 3, 2012 | 11:55 PM
datsuns130's Avatar
Thanks for ur tips sound pretty good
Old May 4, 2012 | 12:12 AM
datsuns130's Avatar
N/a into turbo
I was wondering what was it Needed to make my n/a into the turbo version, and if I do this would I have to rebuilt my motor so it won't blow the engine out?????
Old May 4, 2012 | 02:26 AM
The main issue with turbo swaps is firewall clearance. The turbo z's from factory have a firewall thats recessed a few extra inches to make room for the turbo.
A quick search in google or any zcar forum for 2"80zx turbo conversion" will outline in detail what it takes to do it.
Old May 4, 2012 | 06:41 AM
^^^ There's no firewall fitment issue. All LHD 280zx firewalls are the same. The only fitment issue is if the car is a 79-81 and has the steering box instead of rack & pinion. In that case the turbocharger wastegate bracket has to be cut, or swap to rack & pinion.
But yes, please SEARCH. This topic has been discussed so much, the horse died about 5 years ago.
Old May 4, 2012 | 10:01 AM
A turbo.
Unless you search enough, you're better off buying an L28ET instead of gathering parts to fit them to your L28E, you may actually end up spending more money to retrofit your old motor, than just buying a new one.
