Starter Jump Start
I'm a bit tipsy but i've been working on my car and i've been trying to start it by jumping the starter and it only spins the started but doesnt engage the solenoid and doesnt spin the flywheel which starts the car, anyo0fnne know why brand new starter shouldnt be doing this any advice?
will edit tomorrow for not-faggotry. |
is the ignition on?..because the fuel pump needs to be on before you attempt to bypass the starter....and are the wires on the right terminal of the starter?
Originally Posted by vitaminZ
(Post 277371)
the ignition doesn't need to be on to jump the starter motor.. if its jumped correctly the starter motor should still spin and engage the flywheel.. are you jumping the positive terminal on the solenoid and the terminal where the yellow wire connects to?
Originally Posted by icice9
(Post 277393)
I'm still curious as to what the sunofabitch did to create this bullshit. Can ANYONE tell me which wire directly goes from the ignition switch, to wherever? Manual says the Yellow wire from the ignition... Correct? Then where does that go? |
| All times are GMT -7. The time now is 09:05 PM. |
