Soo close....
Old Mar 7, 2011 | 09:56 PM
Soo close....
....must... hold.... on...... growing weaker....
Old Mar 8, 2011 | 09:21 PM
AKZX's Avatar
Updates?
Haha
Old Mar 8, 2011 | 11:18 PM
Originally Posted by AKZX
Updates?
Haha
Seven more sleeps....
Old Mar 9, 2011 | 05:36 PM
Paper work recieved by US Customs.... baby steps....
Old Mar 9, 2011 | 06:22 PM
Are you legal yet?
Old Mar 10, 2011 | 12:05 PM
Originally Posted by Bleach
Are you legal yet?
You should have asked that before what happened last night.....
Old Mar 10, 2011 | 03:08 PM
was she legal?
Old Mar 10, 2011 | 06:39 PM
im confused. more details. age, etc...
Old Mar 11, 2011 | 09:21 AM
You don't want details you just want pictures ;P
Old Mar 13, 2011 | 11:22 AM
Only made another 313 and that was the end of the era....
Two more sleeps.... this better not be a wild goose chase.....
Old Mar 15, 2011 | 09:44 PM
Doh I forgot to take some pictures before I droped 'er off at the garage to get the vehicle inspection to import my 1983 280ZX TURBO.... finally!
She's a little on the rough side (gee what Datsun isn't now adays unless it's been restored...) but its weird. The rockers, rails, wheel wells front and back, front strut tower what I could see under the car are all solid. The rear hatch is rotten but the frame around the hatch is solid even where the water sits all the time. The spare wheel well had some rusty water in there but its solid too - even down inside the inner fenders below. I think it must have had a rear ender though because its pretty rotten under the tail lights which I haven't seen before on a car that isn't already rotten elsewhere. There is some rust at the bottom of the front fenders and surface on the very front of the hood. Over all a nice solid well running car. One of the last ZXT's made too. Has the BW T5 which seems pretty good - a little notchy as everyone says but really not that bad. Happy to find a five speed as well - icing on the cake.
Alas since I have a very cherry NA and I've started buidling the motor to do the turbo swap the ZXT will be my very own personal test mule! Now I've got a working turbo platform to test my bits and pieces, set up my Mega Squirt III, etc. I wanted to do a shaved rear end as well so since it's rotten around the tail lights I've given myself permision to mess around with it and I don't have to worry about wreaking a perfectly good car
I'll find out tomorow what it needs to pass inspection so I can finish the import process and register the vehicle.
Even though it's a test mule I am SOOOO tempted to do something to the stock supension. It kills me driving these cars with that mushy mushy rolly polly suspension. I'd rather drive my NA with the springs/struts than the more powerful turbo with the stock suspension.... sigh....
Old Mar 16, 2011 | 06:52 AM
pix or it didnt happen.
Old Mar 16, 2011 | 09:33 AM
Lol - fair enough. I'll pick it up tonight with the "to do" list.....
Old Mar 21, 2011 | 09:53 AM
Here are some pictures of the beasty I quickly took before I left town....
Attached Thumbnails Soo close....-280zxt-1.jpg   Soo close....-280zxt-2.jpg   Soo close....-280zxt-3.jpg   Soo close....-280zxt-4.jpg   Soo close....-280zxt-5.jpg
Old Mar 21, 2011 | 09:57 AM
Smokin!!!!
Old Mar 21, 2011 | 10:00 AM
So to finish my importing I've got to get the safety inspection completed which didn't turn out too bad. All she needs is:
Battery hold down
Steering rack boots (on order)
Wheel bearings - rear (on order)
Front brake lines (on order - Earls stainless steel)
TC Rod bushings (on order)
No defrost - I'll pull the dash and see what's up with that. I've got to strip the interior anyhow because the carpet stinks both figuratively and literally. Might jumper the relays so it only blows on the window. We'll see on that one.
Overall not too bad
Old Mar 21, 2011 | 11:07 AM
Wow... all those must be fixed to pass safety? Man... they are picky!
Looks like your vent system is the ACC auto climate? Interesting that the defrost doesn't work... it should default to defrost if the system fails. Do any of the other positions work on the slider?
Old Mar 21, 2011 | 12:39 PM
I think the safety thing is a good thing. There are way to many dangerous hunks of junk driving around out there. The TC bushings might be a little bit of overkill and torn boots on the steering rack is boarderline but they do need to be replaced in order to prevent premature damage.
Honestly I haven't played with it much at all. I did all the paper work to import the car. Drove down to pick it up. Dropped it off to be inspected. Picked it up the next day from the inspection facility and left for a course in Germany the next. I basically parked the car then ran inside to pack. Lol - I was more interested in tearing into the car than going to Germany for the first time
I do remember driving it back that the Economy worked in economy mode (eg the engine didn't rev up to use it) and the 1,2,3 worked appropriately but I didn't check to see where everything was venting too. We were dashing to the boarder to get there before they closed their offices at 3:30 PM. The temp lever also wouldn't slide all the way to the left either.
Old Mar 21, 2011 | 02:50 PM
you know, I sell something that fixes that Auto Climate Control ...
Its called a manual heater control
Old Mar 21, 2011 | 04:34 PM
Yea but your prices are sooooo high!
K here's an I'm lazy question - does the manual control get rid of the pneumatic relay nightmare behind the dash?
Old Mar 21, 2011 | 07:07 PM
Somewhat yes. The manual climate is still controlled by vacuum, but there are fewer lines to cause vacuum leaks, and the system will still activate the fan whenever you want because you physically have to turn it on.
Old Mar 21, 2011 | 09:26 PM
BlueKitsune's Avatar
Intrawebz Wizard
Where does everybody get these really clean 280ZXTs at???
Old Mar 22, 2011 | 06:25 AM
nice work fricfrac. all the good stuff is in washington for not bad prices either. looks like one of the accesory drive belts is torn apart and hanging on the ground. and yuck on the digital dash and auto climate.
Old Mar 22, 2011 | 07:23 AM
My house. I've got a secret stash of them
Old Mar 22, 2011 | 09:21 AM
Trust me the Pacific North West is not the place to look for a clean Datsun of any sort..... I've been hunting BC, Washington and Oregon for one for the last two years and there just isn't much out there that isn't rotten.
Cali, Arizona, etc. That's the place to find a clean S130 but you need to get your interiors and rubber from the soggy places
